- 2016 Scion iA
Ok, for those of you that haven't followed my thread in the Autocross section, I have decided to fill my stock motor mount with urethane. The benefit to this will hopefully be less sloppy shifts and reduced engine movement. I have the AWR mount, but decided to go a different route.
The AWR motor mount compared to stock
After some minor research, I ran across several DIY from people who had filled the gapped areas in their motor mounts. I decided to follow the advice of one of these DIYers and try it on our rear mount: (only thing different is that I used 60A urethane because my car is daily driven, and degreaser instead of MEK to clean the rubber mount. )
60A is right in the middle... not too hard but (hopefully) not too soft. I figure with 1.5L of fury, there is not much torque against it and 60A would be plenty.
This is what i used, 60A Durometer liquid urethane. (McMaster Carr Part no. 8644K24)
Look at all that space to be filled!
Hmm flashing that needs to be trimmed....
I taped off one side using duct tape per the instructions. I did not get a picture of this for some reason.. :shrug:
Leveling. Getting ready to pour it in...
Poured. The stuff is like syrup. Due to the chemical reaction, the liquid is warm... weird.
After a few hours:
Pretty side
Not so pretty side
The duct tape was a little difficult to remove without tearing the urethane. I don't know if it would be better to leave it on longer (so the urethane would be harder), or to have removed it sooner.
It takes a full 2 days to harden to 90% and won't be hardened fully for 7 days. I will likely install after 2 days and get an idea on the amount of NVH that occurs.
So far, easy, easy, easy...
I will continue to update once I can get it installed....
After a few hours:
Pretty side
Not so pretty side
