Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: Pinging on mazda protege5
  1. #1
    Registered Member
    Mazda Protege5 2003
    Join Date
    Jun 2011
    Location
    Charlotte
    Posts
    160
    Blog Entries
    1
    Hey guys so I have one question for you all..
    I have recently been having a problem with pinging on my mazda protege5 2003, 145,xxx miles, and decided to do a seafoam treatment. I did a two can use with one in the gas tank and half of the other into the brake booster. It smoked a little. The pinging problem mostly went away and now it returned again. But anyways the pinging usually happens under load usually when in 2nd-4th gear and accelerating. Ive been trying so hard to get this problem resolved but still dont know what the issue is. usually pinging is alot louder when the temp outside is hot. I really think it might be spark plug issue and just need to change them out, but wanted to hear some prof. opinions and I really dont think its my cat, egr valve, or any wires. Please let me know cause ive been dieing to fix this and dont need to spend much money since im going to school. THANKS ALOT!!
  2. #2
    Wiggity-Wack-O-Tack njaremka's Avatar
    Donated: $0.61
    2011 MX5 GT
    Join Date
    Nov 2001
    Location
    Glastonbury, CT
    Posts
    6,852
    have you tried bumping the gas level? if 87 pings, does 89? if 89 pings, does 91+? if fuel 'premium' level doesnt change it, then something else is seriously wrong, and you will need to have a mechanic check it out.
    Nik
    2011 Black MX-5 GT
  3. #3
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,624
    Have you ever changed the spark plugs? If not, stop wasting your money on seafoam and get 4 new plugs.
  4. #4
    Registered Member
    Mazda Protege5 2003
    Join Date
    Jun 2011
    Location
    Charlotte
    Posts
    160
    Blog Entries
    1
    Yah i've been putting in 89 octane and it usually takes it completely away but when I put 87 in her then it def gets alot worse. I mean i still would rather figure out the problem and fix it if its an easy fix, I mean plus its required gas is 87. And yah cheeseHelmet i actually just ordered some new sparkplugs and there on there way, I read the Copper NGK V-power ones are legit, is that a good choice? Also when I seafoamed the car and was trying to start it after hydrolocking I realized sparks when cranking the car right where the spark plug wires connect to the coil. So im going to buy some wires as well but do you think just changing the wires and plugs will do?
    Thanks alot guys for the help cause its been killing me everyday I drive it, cause I love her. hahha.
  5. #5
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,624
    Wires and plugs are definitely a good idea. NGK plugs is what Mazda recommends, I have the NGK wires too, they're just like OEM ones. You might also want to replace the coilpacks too, especially if they're the original ones.
    Regarding using Seafoam, when you're pouring it into the engine you shouldn't pour it so fast that it stalls right away. You have to keep the throttle open and slowly pour it in, the engine will run like shit but won't stall until you close the throttle. Also, you're not hydrolocking the engine, you're simply making the mixture so rich that it can't possibly combust. That being said, I'm not a believer in Seafoam, if you use good gas you shouldn't need to be using additives like Seafoam to clean out your engine.
  6. #6
    Registered Member
    Mazda Protege5 2003
    Join Date
    Jun 2011
    Location
    Charlotte
    Posts
    160
    Blog Entries
    1
    Wink
    Alright sounds good I'll definetly get some wires with it too then and see how it goes from there. I was wondering what is the right spark plug gap for the car (Mazda Protege 5 2003). I read anywhere from 0.34 in to 0.40 is stock size. And I got the the Copper NGK V-Power ones which are pregapped at 0.44 in are those a good idea? Should I get them checked and regapped to 0.40 or should I keep them like that. I also heard that the bigger the gap then the better the idle which ive had a few problems with. Also was wondering if that was a good spark plug decision with the v-powers or not?
    Thanks again,
    Sorry for all the question, ha
  7. #7
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,806
    If it stops pinging with 89 then using a higher octane gas would be your easy solution 87 is the lowest octane you can put in it not the required rating you could put 112 octane in it if you want. Btw when was the last time you changed the oil?I'm asking because my mom put 17k miles on her car and it started pinging. I would say change your plugs and go from there especially since your having a rough idle a spark plug could have a weak spark which would explain the higher octane helping it
  8. #8
    Registered Member
    Join Date
    Sep 2009
    Location
    Montreal, Quebec
    Posts
    2,624
    Quote Originally Posted by kosteniuks17 View Post
    Thanks again,
    The plugs should come pre-gapped, you needn't gap them yourself. The service manual says that the gap should be 1.0mm to 1.1mm (or 0.040 to 0.043 inches).
    Mazda recommends two NGK part numbers, BKR5E-11 and BKR6E-11. What you ordered should have a similar part number (BKRxE-11). BKR5E-11 is the normal plug, but you might want to try BKR6E-11 since it's one step colder.
  9. #9
    Registered Member
    Mazda Protege5 2003
    Join Date
    Jun 2011
    Location
    Charlotte
    Posts
    160
    Blog Entries
    1
    Sounds good yah I checked my plugs and its pregapped to 0.044 in and the part number is the BKR5E-11 ones so I think I should be alright. I also just got the NGK wires so I'll def change them this weekend. But yah Tweety I def changed the oil and its been maintained very well, so I know thats not the problem. Im just not sure that just changing these plugs and wires will fix the pinging which is what im worried about. But I guess I'll find out soon and let you know what happens.
  10. #10
    Registered Member
    Donated: 10$
    Join Date
    Jun 2003
    Location
    Balt/Wash
    Posts
    4,269
    Clean the MAF
    03.5 P5 Laser Blue 284K miles, and now Totalled twice.
    02 P5 Midnight Blue 211K Totalled
    02 P5 Sunlight Silver 142K
    96 318ti Boston Grun 185K
    89 Country Squire 192K
  11. #11
    the zoom... RockerPro5's Avatar
    Midnight Blue Protege 5
    Join Date
    Sep 2007
    Location
    Calgary, AB
    Posts
    166
    Here is my take in addition to above posts:
    - Could be lots of carbon build up. If you rev up the engine to redline momentarily, does a lot of black smoke come out? [Excess carbon build up will create more compression, and would cause pre-detonation]
    - Are you using good quality gas? http://www.toptiergas.com/retailers.html
    - After changing the plugs, see if there is something out of the ordinary with the old plugs (pre-det. excess carbon etc.)
    - While using higher octane a good run on the highway might help to burn off the carbon, if this is the case.
    2002 (bluep5)
  12. #12
    Registered Member
    Mazda Protege5 2003
    Join Date
    Jun 2011
    Location
    Charlotte
    Posts
    160
    Blog Entries
    1
    so I changed all four spark plugs and spark plug wires and the problem is still there. I have no idea what other problem it could be? Usually just rattles in second or third but thats it and when under load. I also cleaned the MAF recently so i doubt thats it. I read that it could possibly be a tie rod, or the heat shield but im not sure. Anymore suggestions?
  13. #13
    Registered Member
    Mazda Protege5 2003
    Join Date
    Jun 2011
    Location
    Charlotte
    Posts
    160
    Blog Entries
    1
    Its also not carbon build up because I just recently seafoamed the car, but the problem does go away when I use a higher octane fuel....
  14. #14
    Registered Member o.g.sk8er's Avatar
    Join Date
    Jul 2002
    Location
    los angeles, ca
    Posts
    1,505
    my car has pinged since day one.
    I've tried everything...plugs, different gaps, egr, wires, coils, etc...I always use premium fuel as well. I find seafoam in the gas tank helps a bit. But I have just come to live with it. Bought the car with 4 miles, now has 120xxx. Has pinged the entire time. lol
    Stanced Member No. 5
  15. #15
    Registered Member
    Mazda Protege5 2003
    Join Date
    Jun 2011
    Location
    Charlotte
    Posts
    160
    Blog Entries
    1
    yah man i think ive decided to give up on this thing. I mean the spark plugs, wires, and seafoam def helped out the car in mpg, performance, and did take the sound away a lot, but im guessing this is something im going to have to accept Im just worried it doesnt break something bad you know. But i guess im just going to have to use some higher octane fuel and live with it ha. Hopefully it'll last me.
Similar Threads
  1. Help with Pinging?
    By delavp5 in forum Protege5 Lounge
    Last Post: 07-27-2010, 02:48 PM
  2. Pinging in your MS3
    By fastgascar in forum MS3 Engine & Transmission
    Last Post: 05-21-2008, 05:09 PM
  3. Why am I pinging???
    By kicker22705 in forum Mazda Tech & How-To
    Last Post: 03-23-2008, 11:49 AM
  4. Pinging?
    By newprot5fan in forum Protege5 Lounge
    Last Post: 07-02-2007, 03:55 AM
  5. i think i'm getting pinging
    By kicker22705 in forum MSP Performance
    Last Post: 12-04-2006, 02:48 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
