Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 8 of 8
Thread: Manual Transmission dipstick location.
  1. #1
    Registered User
    2012 Mazda5 6M
    Join Date
    Mar 2011
    Location
    Richmond, VA
    Posts
    18
    I was wondering if anyone know the location of the dipstick on the 6 spd manual. I have looked under the hood and consulted the owners manual, but cannot find the dipstick. I had mentioned in a previous post that there is a vibration in the gas pedal in 4th while accelerating 2200 up to about 2700 like a harmonic and there was a recomendation tho check the fluid. I have noticed it does not do it all the time and it does happen in the higher gears. My suspicion is a phase harmonic between the engine, tranny and tires at certain rpm and road speed. I would think if there was a fluid problem it would be VERY noticeable.
    Stuart
    Just realized this is in the wrong forum. Is it possible to move to the drivetrain forum?
  2. #2
    Registered User johnnieboy's Avatar
    2012 Mazda5 Grand Touring
    Join Date
    May 2011
    Location
    San Diego
    Posts
    96
    This may not help you, but...
    My 2012 Mazda5 GT has an automatic, but the location of the trans and perhaps the dipstick might be similar to the manual. My trans dipstick is neon orange and is located as follows, when facing the engine from the front:
    ...About four inches to the right of the right-most edge of the large black plastic engine cover.
    ...About halfway between the back edge of the large black plastic engine cover and the rear firewall.
    ...It's located moderately low, but the orange handle is easily seen when looking in the right area (only slight leaning forward is necessary).
    Hope this helps.
    Regards from Sunny San Diego................Tom
  3. #3
    Registered User J.P.'s Avatar
    09 Mazda 5 GT, '88 GTX
    Join Date
    Apr 2004
    Location
    Kingston, Ontario
    Posts
    172
    No dipstick on the M/T - just a fill plug on the side of the tranny.
    2009 Mazda 5 GT
    1988 Mazda 323 GTX
  4. #4
    05 MZ3 HB/09 MZ5 jimp's Avatar
    2005 Mazda 3 HB 5 speed
    Join Date
    Nov 2008
    Location
    EAST TN
    Posts
    158
    will have to remove the fill plug, and using a finger, (pinkie works best) if you can feel gear oil with only the 1st digit of the pinkin in the fill hole, you're good to go
  5. #5
    Registered User
    Join Date
    Oct 2005
    Location
    Illinois (U.S.)
    Posts
    701
    Have you seen transmission fluid on your garage floor or in your driveway? I've never heard of leaks from a manual transmission.
    As mentioned above, there is no dipstick with a manual transmission. There will be two bolts on your transmission, on my Honda Accord they were behind the pasenger side tire. Remove the top bolt and as mentioned above, stick your finger in. If you feel liquid your level is OK.
    When it comes time to change your transmission fluid... remove the top bolt, put it back. Remove the bottom bolt, put a pan underneath to catch the liquid. Remove the top bolt (now loosened). When everything has drained out, replace the bottom bolt and put in the transmission fluid in the top bolt until it can't take anymore (it'll start leaking out). Replace the top bolt. The owner's manual will say what the capacity is, I'd buy the fluid from your local Mazda dealer. On my Honda Accord it was 3.1 quarts (yes, I had to buy 4 quarts).
  6. #6
    Registered User chromal's Avatar
    2010 Mazda Mazda3 s Sport 6-spd
    Join Date
    Aug 2010
    Location
    8700ft SW Denver foothills
    Posts
    75
    Yeah, manual transmissions and MTF don't generally require servicing often. They don't "burn through" oil, hence it's fairly common for them to only have drain and fill plugs, no dipstick. There's not even a recommended MTF change interval based on time or miles in the Mazda service schedule or shop manual, at least not for the Mazda3. Most people I've read on forums changing it do so out of an abudance of caution, or a desire to replace the OEM oil with their preferred brand and type (Redline brand synthetic MTF is one popular replacement).
  7. #7
    Registered User
    2007 Mazda 5 GT 5MT
    Join Date
    Apr 2009
    Location
    Port Coquitlam, BC
    Posts
    1,356
    I prefer Red Line MT-90. I'm probably going to do the change soon.
    2012 Mazda 3 GS-Sky 6MT Previously: 2007 Mazda 5 GT 5MT
  8. #8
    Lover of 5's Robotaz's Avatar
    2009 Mazda5 GT
    Join Date
    Aug 2009
    Location
    Mexington, KY
    Posts
    1,221
    You can check your clutch fluid level though by locating the reservoir under the hood. It takes brake fluid if you need to top it off. I would buy the Mazda stuff unless you bleed it all out and start over. Then I would use a higher-quality synthetic.
    One thing you need to watch for; the fill plug on your MTX will not reflect the correct level unless the entire car is level. That isn't easy to do in most cases. I would ask a Jiffy Lube type place to check it for you so that it is perfectly level, unless of course you have a lift at your house. Ask them to report if it drains out at all when the fill plug is removed. You want a little bit to barely be running out; enough to drip slowly if allowed to run down the tranny.
Similar Threads
  1. manual transmission oil
    By Tiajaunatoad in forum Mazda Protege 5 (Protege5.com)
    Last Post: 02-26-2012, 03:32 PM
  2. 1.6l automatic transmission swap to a manual transmission
    By Protege-Fiend in forum Protege Performance
    Last Post: 06-22-2010, 06:00 PM
  3. Manual Transmission
    By danguyon in forum Mazda Protege 5 (Protege5.com)
    Last Post: 01-26-2008, 12:00 AM
  4. Transmission dipstick...do we have one?
    By Stormtrooper77 in forum MSP Engine, Performance & Forced Induction
    Last Post: 02-20-2006, 04:40 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
