Your Best Source for Genuine Mazda Parts!
Results 1 to 14 of 14
Thread: Mazda Protege/Protege5 Audio Wire Diagram
  1. #1
    Registered Member goyatech's Avatar
    2005 Mazda 3
    Join Date
    Oct 2010
    Location
    Reading, PA
    Posts
    183
    I know a lot of you guys are looking for this. I was too, till i came across it and decided to share with you.
    Dont Forget To Say Thanks...
    I found a great way to attract money... work!
  2. #2
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    Posts
    7,069
    Thanks, now isn't this in the service manual that's stickied at the top of the P5 section?
  3. #3
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    wouldn't need this if people just bought the wire kit when they install stereos....
  4. #4
    Supercharged CDN P5 bikingpro5's Avatar
    03 Protege5
    Join Date
    Jan 2008
    Location
    NB, Canada
    Posts
    4,544
    Quote Originally Posted by tweety2300 View Post
    +1 wire harness is so much easier to use. even with only 4 wires connected in my stereo..
  5. #5
    2005 Mazda 3
    Join Date
    Oct 2010
    Location
    Reading, PA
    Posts
    183
    If you read the post its for people that changed the rear door speakers and couldnt figure out the colors... as it shows in different colors.
  6. #6
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    I did read the post it says nothing about rear door speakers. Also I'm pretty sure there's only 2 wires going to a rear door speaker on both sides. Not quite sure what your argument here is but if you can't simply swap out rear door speakers you don't need to be messing with it. Its a universal concept hot wire will be a solid color while ground is either black or has a black stripe going through it.
  7. #7
    SSAudio.com denim's Avatar
    2003 Protege5 5-speed / 2005 RX-8 Skinka
    Join Date
    Sep 2010
    Location
    SSA HQ East
    Posts
    368
    Thank you.
    2003 Protege5 - 5speed
    {NGK Plugs & Wires / 20% Tint / Injen CAI / Azuelke 8mm spacers / MP3 ECU / TWM Short shift / AWR 21.5mm Rear Sway / KYB Struts / Eibach Pro-Kit springs / SR Motorsports Exhaust & CAM shafts/ PIAA Fogs / DDM 55w HID's / SoundDeadenerShowdown / StopTech rotors & pads / EZLip / XS Power D5100R & XP 750 / Pioneer PRS880 / Fountek 89's / Ascendant Carbon's / ZED Audio Ra & Minotaur & Draconia / Audio Control Matrix / SSA Zcon 12D2}
    2005 RX-8 Shinka Edition
    {20% Tint / HKS AF / TurboXS Exhaust & Cat pipe / GarageLine spacers / Enkei 17x9 / Toyo R1R 275 / Eibach ProKit springs / BHR Ignition / Tokico SpecD adjustable shocks / EZ-Lip}
    SSAudio.com
    CarAudio-Forum.com
    CarAudioResources.com
    HomeAudioForum.net
    Aaron Clinton
    SSAudio Inc.
  8. #8
    Registered Member Jordysoso's Avatar
    2003 Mazda Protege5
    Join Date
    May 2011
    Location
    Amherst, Ohio
    Posts
    1,571
    can u run the sub that comes in the trunk on top of the spare tire if u get an aftermarket headunit without any extra wiring besides the vehicle specific harness?
    2003.5 Mazda Protege5
    http://www.mazdas247.com/forum/showt...44#post5910444
    Tired of rising gas prices?
  9. #9
    2005 Mazda 3
    Join Date
    Oct 2010
    Location
    Reading, PA
    Posts
    183
    there is more than 2 wires remember you have the power windows power locks etc... and if you look at the diagram the hot wire has the stripe.
  10. #10
    2005 Mazda 3
    Join Date
    Oct 2010
    Location
    Reading, PA
    Posts
    183
  11. #11
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    I wouldn't know I have a wire kit curtesy of crutchfield. I'm not trying to insult you in any way don't get me wrong but if you change the rear door speakers why wouldn't you use the factory wires? I mean thers 8 wires all together for the speakers but it is odd that the hot wire has a stripe so I do have to say good find because that would confuse the hell out of me.
  12. #12
    Registered Member P5Zac's Avatar
    2002 Mazda Protege5
    Join Date
    Feb 2012
    Location
    Porterville CA
    Posts
    126
    HELP!!! So ive been in the process of upgrading my speakers with Infinity Kappa's. The back doors went in without a problem. Just went to install my passenger front door speaker and now my whole stereo isnt working....I had the stock speaker taken out for about 2 days before i got around to installing the new infinity kappa and the stereo was still working fine. I followed the wire diagram to the T and after wiring up the new speaker a couple hours ago now the whole system doesnt work anymore. Even when i remove that speaker the system doesnt work....did i possibly blow a fuse somewhere or what else could have gone wrong? please help with any suggestions you might have!
  13. #13
    "Amigo del Wraith"
    Donated: $5
    Join Date
    Jul 2005
    Location
    USA
    Posts
    1,229
    Have you checked if you did blow a fuse? My guess is you caused a short and blew the radio fuse either on the radio itself or the one in your fuse box.
  14. #14
    2002 Mazda Protege5
    Join Date
    Feb 2012
    Location
    Porterville CA
    Posts
    126
    well after turning the car on and off (ACC position) to see if it would kick the sound on with no luck, after actually starting the car and pulling it back in to its regular parking spot i turned the car off, realized i left the back windows up, turned it back to ACC and rolled up the windows....while i was doing this the music turned on but id did not don on me that the music was playing until after i turned the car back off again...stupid me haha so after a few more attempts of switching the car back on i could not get the sound to produce again....if it was a fuse i doubt it would have done that...but i havnt checked the fuse yet, here soon im gonna pull all the panels and check for grounding out wires and check the fuse. ill report back with what i find.
Similar Threads
  1. Replies: 12
    Last Post: 11-12-2010, 11:00 PM
  2. serrvice and wire diagram manuals M5
    By mapinzon in forum Mazda5 Lounge
    Last Post: 04-08-2009, 09:38 PM
  3. The radio wire harness diagram
    By gary0803 in forum Protege5 Lounge
    Last Post: 10-12-2007, 11:07 PM
  4. Wire diagram anyone?
    By kobaq7 in forum MSP Audio
    Last Post: 04-24-2007, 08:43 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
