Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 11 of 11
Thread: 2002 MP5 will crank but won't start
  1. #1
    Registered Member
    Protege5
    Join Date
    Apr 2011
    Location
    Luberton, TX
    Posts
    1
    First, this my first post, so I should say hi. I just got a 2002 MP5 with about 120K on it. Had the car for a couple of weeks without any problems.
    This week, I went on a business trip and left my car at the airport for since Monday. I got back this afternoon and could not get the car to start. It cranks, but won't fire up. I left the car at the airport for the night, but I am heading back tomorrow to see what I can do. Does anybody have any suggestions on something to look for?
    Thanks,
    Jim
  2. #2
    out to pasture... MazdaSpeeder's Avatar
    Protege5 (5-spd)
    Join Date
    May 2007
    Location
    Kentucky
    Posts
    2,672
    If it cranks over and over, then it's probably the starter. If it cranks but then sort of winds down, it's the battery. You can try tapping on the starter...often a starter that's going can be coaxed into working by tapping it with a hammer. If it's the battery, try jumping it. GL.
    Massive Performance and OEM Part-Out Thread
    Alpine Head Unit & Pioneer Speakers - MSP Radio Pocket - SLS Gauge Rings - Greddy Weighted Shift Knob - Momo EBrake
    35% Front, 25% Rear Tint - DDM 4300K HIDs - Wipac Fogs - Stoptech Pads - DRT Slotted Rotors - Optima Red Top
    NGK Long-Reach Plugs - 1.8L Coil Packs - Fiamm Low-Tone Horn - MP3 ECU -
    RR Racing UDP - Simota Twin Charger CAI - Magnaflow Cat-Back
    SLS Midpipe - Tsudo Header -
    Corksport Exhaust Hangers - AWR & RR Racing Inserts - Kartboy SS & Bushings - Sumitomo HTR+ 215/40/16
  3. #3
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    Just curious how could the starter be bad if it turns over? If its turning over. It might not be geting spark
  4. #4
    Registered Member
    Join Date
    Oct 2008
    Posts
    25
    Depending on mileage. I'd say 2002 - somewhere near 100,000. First take off oil filler cap, have someone with flashlight look into hole and while you crank over engine see if camshaft turns, if not. Replace Timing belt !
  5. #5
    Registered Member
    Join Date
    Oct 2008
    Posts
    25
    If that's the case look on here for a timing belt complete change guide. Someone posted with full pics while he did his print it out and read very carefully all his tips and writings helped a great deal and saved a ton of time.
  6. #6
    Registered Member
    Join Date
    Oct 2008
    Posts
    25
    Here's the link http://www.mazdas247.com/forum/showt...tion-with-pics!
    Make sure to read everything. Lots of time saving tips!!!!
  7. #7
    Banned
    Rust Bucket
    Join Date
    Oct 2007
    Location
    Linden/Charlotte NC
    Posts
    8,565
    check the battery before you mess with anything else, always do easiest stuff first
  8. #8
    Registered Member
    Join Date
    Oct 2008
    Posts
    25
    If it turns over and it is not firing it is not the battery.
  9. #9
    4ever needin' work Alamo1's Avatar
    Midnight P5 '02
    Join Date
    Apr 2009
    Location
    Cochrane, AB
    Posts
    1,206
    +2 on the timing belt check. Also I'd pull a plug and see how they look. If they are all black and wet, you may need to replace them. They should look a little sooty and mostly white.
    Try turning it over for 30 seconds or so and then go smell the tail pipe and see if it smells like gas. If it does, you most likely don't have spark, if not then you may not be getting fuel.
  10. #10
    Registered Member
    MAZDA,PROTEGE5
    Join Date
    Sep 2012
    Location
    United States
    Posts
    2
    Does anyone know if there are any security switches (neutral safety switch and the like) that could keep the car from starting?
  11. #11
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,803
    There's one on the clutch pedal. The alarm could have also freaked out,
Similar Threads
  1. Replies: 20
    Last Post: 09-09-2012, 06:45 AM
  2. Will crank, no start.
    By Krazykaveman in forum Protege Lounge
    Last Post: 03-22-2010, 01:29 AM
  3. Cold start at 32F, no crank 1st/2nd attempt but start?
    By Marik123 in forum Protege Performance
    Last Post: 01-03-2010, 10:24 AM
  4. hard to start / long crank
    By c4racer in forum Protege5 Lounge
    Last Post: 05-22-2009, 02:33 AM
  5. 626 will crank, but not start
    By jalbao in forum Other Lounge
    Last Post: 04-27-2008, 10:57 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
