Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 4 of 4
Thread: Gas tank filling problems at the pump, who can help.
  1. #1
    Registered Member
    Mazda Protege 5
    Join Date
    May 2007
    Location
    Warren, MI
    Posts
    161
    I have a 02 P5, and as of the past few months my trips to the gas pump were rediculously timely. Maybe it is my car trying to reject the oil companies monopoly.
    Every time I try to fill the tank the gas gets backed into the fill neck and trips the pump handle stop. It will happen around 1.2 gal to pop the handle the first time and then every .05 gal if you try to fill it quickly. I've taken up to 35 mins to fill my tank of what, 13 gallons? A real bummer when you're driving Atl to Detroit trying to keep a good trip avgerage speed.
    I did use to top off the tank to keep an accurate record of my mpg and fuel costs. I just fell off writing it all down eventually and stopped topping off. I am sure because of this the vent is cloged up or something of the sort. I went peaking around to try and see if I could find the vent but it was late december in Detroit and I was frozen.
    Who knows where the vent is accessable to run a snake or compressed air down to clear a possible clog? I do know the little hole in on the 12 o'clock spot above the fill hole is nothing more the a hole in a peice of metal, vent. Any pictures of the parts might help too.
    Thanks in advance.
    (Sent from phone, please excuse any spelling/missing letters)
  2. #2
    Geology Rocks bucksatan's Avatar
    2002 Mazda Protege5
    Join Date
    Aug 2006
    Location
    Dundas, Ontario
    Posts
    590
    Probably spiders in the vent system. Yes, that is the recall on newer ones, but based on the experience of some guys in Toronto it impacts the protege as well.
    One thing I, and some people I know, have done when having trouble filling the tank is to turn the handle upside down. Looks silly, but it seems to keep it from cutting out all the time. Give that a try and see if it helps at all.
    2011 Mustang GT/California Special
  3. #3
    Registered Member
    Mazda Protege 5
    Join Date
    May 2007
    Location
    Warren, MI
    Posts
    161
    I am getting a bad trunk leak with water too, so who knows maybe it is the spiders getting into other mischevious things as well.
  4. #4
    Registered Member
    3 P5
    Join Date
    Jan 2010
    Location
    Wisconsin USA
    Posts
    275
    Did '2 0r '3 have a small spring loaded flap at the top of the fill tube that could fall off, drop down and slow the fill process?
    Thought mine had this and fell off yrs ago.
    Could have just been a past car.
Similar Threads
  1. Could the in tank pump be the real problem?
    By nig3 in forum MS3 Engine & Transmission
    Last Post: 01-08-2008, 01:48 PM
  2. Gas tank only filling up halfway
    By rayray2030 in forum Protege5 Lounge
    Last Post: 12-29-2005, 07:00 PM
  3. Walbro 255 LPH In-Tank Fuel Pump is in.
    By GOTZOOM? in forum Mazda Tech & How-To
    Last Post: 07-04-2003, 06:26 PM
  4. Walbro 255 LPH In-Tank Fuel Pump is in.
    By GOTZOOM? in forum Protege Performance
    Last Post: 07-02-2003, 10:05 PM
  5. OVER FILLING GAS TANK
    By <MP3110> in forum Mazda MP3 Lounge
    Last Post: 02-28-2002, 08:07 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
