Your Best Source for Genuine Mazda Parts!
Results 1 to 4 of 4
Thread: 2001 Mazda Millenia 2.5 liter engine (Car would not start, electronic components work
  1. #1
    Registered Member
    2001 Mazda, Millenia 2.5 Engineer
    Join Date
    Feb 2011
    Location
    Maryland
    Posts
    2
    Hopefully someone can help.
    When I put the key in the ignition and tried to start the car, nothing happened. All the electric components worked, but the car would not start. This has happened several times over the last week. Not sure if it's the starter, alternator or something else. If someone has had the same problem and resolved it, I would be grateful for your assistance.
    Thanks!
  2. #2
    N00b Goliat6288's Avatar
    1998 Mazda Millenia L
    Join Date
    Jun 2010
    Location
    Queens, NY
    Posts
    1,229
    welcome to the forum.
    If nothing happens no clicking or if it doesnt turn over... check your battery charge and the ground cable. It might be corroded. If its is disconnect it and use sand paper to clean it off and try it again.
    98 Milly
    Ksport Kontrol Pro Coilovers
    http://www.wheelweights.net/
    "What you put up with, you end up with, you can only expect what you accept from someone."
  3. #3
    Registered Member
    Join Date
    Jan 2008
    Posts
    1
    I have a 2000 2.3L Miller engine with a similar issue. The starter will not engage. I pulled the starter and did a bench test and everything worked fine. there was corrision on the starter terminal which I removed. Reinstalled the unit and the car started fine, but when I tried to restart later it did the same thing. After several turns of the ignition key it started but after shutting off it will not turn over. I'm assuming it is some relay issue between the ignition and the starter and hoping that someone has a idea where I should look. When I turn the key all the normal warning lights are displayed. It is not a battery issue.
    Quote Originally Posted by Goliat6288 View Post
  4. #4
    Registered Member
    Eunos 800, Cosmo 20b
    Join Date
    Mar 2013
    Location
    Germany
    Posts
    5
    hello,
    maybe it is the Engine Injection Relay or its maybe the Engine fuse... did you checked it?
Similar Threads
  1. 2001 Mazda Millenia tcs on/off engine surges please help
    By ihatethisMazda in forum Other Lounge
    Last Post: 11-05-2012, 06:13 PM
  2. 2001 Mazda Millenia Timing Adjustment help
    By gplarkin in forum Other Lounge
    Last Post: 12-16-2009, 11:24 AM
  3. Mazda 4-liter W-12 engine
    By mikeyb in forum Other Lounge
    Last Post: 04-06-2006, 08:08 AM
  4. Losing power/stalling on Mazda Millenia 2001
    By cjmichael in forum Other Lounge
    Last Post: 01-04-2005, 08:33 AM
  5. 95-engine turns over/wont start/horn not work.
    By maxandstac in forum Protege Lounge
    Last Post: 10-21-2004, 04:55 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
