Your Best Source for Genuine Mazda Parts!
Results 1 to 6 of 6
Thread: Recharge A/C freon, is it hard?
  1. #1
    a.k.a. spydermonkey mnkyboy's Avatar
    Join Date
    Feb 2002
    Location
    New Orleans, LA
    Posts
    178
    I think I need to recharge my A/C freon, is this hard? Anyone have a tutorial on how to do this?
    2002 Mazda Protege 5 - Vivid Yellow
  2. #2
    Join Date
    Feb 2002
    Location
    New Orleans, LA
    Posts
    178
    bump.
    Has anyone done this before? Since my car isnt blowing cool air, does this mean I have a leak in the a/c lines?
  3. #3
    ≃ 26 psi? J_Naoto's Avatar
    Marketplace, Protegé & VA Moderator
    2002.5 Protegé LX, 2011 BMW 135i
    Join Date
    Apr 2003
    Location
    Newport News, VA
    Posts
    2,975
    i'd like to know as well. i think this is why my a/c fan doesn't work...
  4. #4
    Join Date
    Feb 2002
    Location
    New Orleans, LA
    Posts
    178
    I ended up recharging my system this weekend. I bought a gauge and can 16oz can of R134a. The gauge said I only had 2-3 psi of pressure in my system. I added (1) can and it rose to about 30 psi. Looks like it should be from 30-45 for full. I didnt add anymore, going to see how long it stays at this pressure.
  5. #5
    Registered Member
    Mazda, Protege5 2002
    Join Date
    Aug 2008
    Location
    Orange County
    Posts
    471
    yes, please report back, there is not alot a info on the forum on ac recharge. also post whaet brand did you use? any additive with it? or did you use one with no additive? let us know how it went.
  6. #6
    aka protege_kid MS3_KIDD's Avatar
    2009 Mazdaspeed3
    Join Date
    Jan 2008
    Location
    Easton, Pa
    Posts
    1,201
    well im assuming you charged your system without having it evacuated so you probable still under charged. the problem when your charging with small cans your self is you cant accurately charge it. theres is a spec sticker under the hood that says the max charge. second is charging a system thats already at atmospheric pressure. most people know better when if comes to messing with their A/C systems. im not sure how much experience you have with mobile ac, but if you must do it your self. im hoping you went with something thats virgin r134a youll only be able to pick it up in 1lb cans since im assuming your not licenced to purchase large quantities. no stop leak and minimal dye but preferably no dye. stop leak=bad. it will clog the small passages and orifices that are critical in your ac system. your compressor, condenser, evaporator core, expansion valve, they all have orifices that can be clogged by stop leak. if you have a leak. leaks are another reason why people take it to the shop, lets face it, your most likely not going to find a leak. if you had a gauge set you can watch your pressure differences and see if you under/over charged and see how well the a/c system is working.
    2009 Mazdaspeed3 Grand Touring
    Cobb SF Intake — Street Unit Silicone Boost Tubes — Street Unit Shifter Spacers — AWR Rear Engine Mount
    HKS SSQV Blow Off Valve — 2nd Cat Delete — JBarone SSP — Yellow Fog Light Overlay — 20% Window Tint
    Hella Supertones — H&R Lowering Springs — Koni Sports "Yellows" — Replica GV Front Lip — HKS Catback
Similar Threads
  1. freon refill?
    By wilsta in forum Protege5 Lounge
    Last Post: 06-24-2010, 03:36 PM
  2. AC recharge...
    By Suspect987 in forum Global
    Last Post: 06-11-2009, 06:57 PM
  3. Air Conditioner Freon Topoff
    By RABID_MP5 in forum Protege5 Lounge
    Last Post: 05-27-2009, 10:31 PM
  4. Broke high pressure freon line for A/C
    By JCell in forum Protege Performance
    Last Post: 05-04-2009, 03:16 PM
  5. recharge ac?
    By bamflee84 in forum MSP Problems
    Last Post: 08-10-2008, 03:52 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
