Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 10 of 10
Thread: Creaking front end noise...It actually worked!
  1. #1
    Registered Member Platinum GT's Avatar
    2007 CX-9 GT AWD, All Options
    Join Date
    Dec 2010
    Location
    GSO, North Carolina
    Posts
    37
    Just spreading my excitement that the tip for greasing the front strut bump stops cured the creaking when going over speed bumps and turning.
    I even got a free set of upper strut bearings out of the deal from the dealership because they couldn't identify the culprit either!
    I highly recommend doing this even if you don't have the noise. Just to prevent it from ever happening.
  2. #2
    Registered Member xarthan's Avatar
    Join Date
    Oct 2009
    Posts
    160
    what sort of grease did you use?
  3. #3
    Join Date
    Dec 2010
    Location
    GSO, North Carolina
    Posts
    37
    White lithium spray attaches well and resists the elements pretty good.
  4. #4
    Registered Member
    2007 Mazda CX-9 GT
    Join Date
    Jan 2011
    Location
    Vancouver BC, Canada
    Posts
    7
    Hi what is the procedure to do this? I also have the creaking noise sometimes when going over speed bumps. Happened after the car was under-washed and detailed so I suspected some lubrication was power-washed off.
  5. #5
    Registered Member Lindyrect's Avatar
    2007 GT FWD, Bose/NAV
    Join Date
    Dec 2007
    Location
    Chula Vista, CA
    Posts
    599
    Ok here is the best way:
    The easiest way is to raise the front end of the 9, if not then deal the hand jack. The goal is to raise the front struts so that they are fully extended. Put your hands in the wheel well and raise the strut boots up one at a time on each side. Spray a white lithium lube on each strut shaft and rub the bump-stop up and down. This should work.
  6. #6
    can I stab u in the shin? peavey's Avatar
    Donated: $15
    MS3
    Join Date
    Jan 2011
    Location
    Crackworth, GA
    Posts
    244
    +1
  7. #7
    Registered Member
    2007 Mazda CX-9 GT
    Join Date
    Jan 2011
    Location
    Posts
    7
    Thanks for the info Lindyrect!
  8. #8
    Registered Member
    Mazda CX-9 Touring
    Join Date
    Jan 2011
    Location
    Brooklyn, NY
    Posts
    4
    Does this work for the rear also?
  9. #9
    Registered Member
    2007 MAZDA CX-9 GT AWD
    Join Date
    Mar 2015
    Location
    United States
    Posts
    3
    I have an '07 and it has been making the same horrible "creaking" noise over bumps at low speeds... I was told that it was front sway bar bushings needing replacement, apparently a common problem and they redesigned them after the 09 model year.... anyone else have and fix this issue?
  10. #10
    Registered Member
    Mazda CX-9 2007
    Join Date
    Jun 2013
    Location
    Netherlands
    Posts
    6
    The grease tip fixed the "noise"on my '07
Similar Threads
  1. Help: Creaking noise around front right wheel.
    By maniac_2oo4 in forum Protege5 Lounge
    Last Post: 02-18-2009, 10:41 PM
  2. Creaking noise
    By dirtyz in forum Protege5 Lounge
    Last Post: 07-18-2008, 01:09 PM
  3. creaking noise
    By BostonAmy in forum CX-7 Lounge
    Last Post: 04-04-2007, 06:44 PM
  4. creaking noise?
    By wildnthestreets in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 01-08-2006, 09:08 PM
  5. Creaking Noise from the front of the car
    By gunners in forum Protege5 Lounge
    Last Post: 04-27-2004, 07:46 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
