EMS Solutions
Quicklinks
Stock ECU reflashed? Info Here
AEM F/IC writeup
HALTECH E6X Install Guide
MegaSquirt 2 EMS Install Guide
Standalone Units
Haltech Platinum Sport 2000
Up to 12 Injector Drivers, Up to 12 Low Impedance, Up to 16 High Impedance Injector outputs. Up to 6 Ignition Outputs. Also has 7 Analog, 1 Digital Switched and 3 Digital Pulsed Additional Programmable Inputs. Additional Programmable Outputs include 4 PWM/DPO and up to 9 Digital Outputs. It has VE Tuning, Datalogging up to 200 samples Per Second (laptop or onboard), closed Loop O2 Control, CAN Output ( Supports IQ3 Dash), USB Communication, Internal Map Sensor (2.5 Bar (up to 22 PSI), Real Time Programming Software (uses ECU Manager Software), Plug and Play Options, Adjustable Resolution (Up to 32x32), The Max Map Sensor Range is 10 bar(130 PSI), It also has Closed Loop Boost control and Custom Censor calibrations.
Haltech Platinum Sport 1000
4 Injector Drivers, Up to 8 Low Impedance, Up to 16 High Impedance Injector outputs. Up to 4 Ignition Outputs. Also has 7 Analog, 1 Digital Switched and 3 Digital Pulsed Additional Programmable Inputs. Additional Programmable Outputs include 4 PWM/DPO and up to 5 Digital Outputs. It has VE Tuning, Datalogging up to 200 samples Per Second (laptop or onboard), closed Loop O2 Control, CAN Output ( Supports IQ3 Dash), USB Communication, Internal Map Sensor (2.5 Bar (up to 22 PSI), Real Time Programming Software (uses ECU Manager Software), Plug and Play Options, Adjustable Resolution (Up to 32x32), The Max Map Sensor Range is 10 bar(130 PSI), It also has Closed Loop Boost control and Custom Censor calibrations.
Haltech Platinum Sprint 500
4 Injector Drivers, Up to 8 High Impedance Injector outputs. Up to 4 Ignition Outputs. Also has 1 Analog (for Wideband) Additional Programmable Inputs. Additional Programmable Outputs include 2 Generic Outputs (switched On/Off Only). It has VE Tuning, Datalogging up to 200 samples Per Second (laptop only), closed Loop O2 Control, CAN Output ( Supports IQ3 Dash), USB Communication, Internal Map Sensor (2.5 Bar (up to 22 PSI), Real Time Programming Software (uses ECU Manager Software), DOES NOT HAVE Plug and Play Options, Adjustable Resolution (Up to 32x32), The Max Map Sensor Range is 10 bar(130 PSI), IT DOES NOT HAVE Closed Loop Boost control And finally it does have Custom Censor calibrations.
Haltech E6x
4 Injector Drivers, Up to 8 Low Impedance, Up to 16 High Impedance Injector outputs. Up to 4 Ignition Outputs. Also has 1 Analog, 1 Auxillary and 1 Trim Input Additional Programmable Inputs. Additional Programmable Outputs include 4 PWM/DPO, 2 Digital and 1 Auxillary. Datalogging up to 200 samples Per Second (Laptop Only), closed Loop O2 Control (Narrow Band Sensor), Internal Map Sensor (2.5 Bar (up to 22 PSI), Real Time Programming Software (uses HalwinX Software), Plug and Play Options, Fixed Resolution to 22x32, The Max Map Sensor Range is 7 bar(87 PSI)
AEM Universal EMS
System is fully enabled—Never pay for upgrades! Runs on Windows™ compatible software, Live help window eases tuning process, Free software updates on aempower.com, Fuel table automapping, Programmable traction control, Onboard 512kb datalogger, Up to 10 cylinder sequential fuel injection, 10 independent peak & hold injector drivers, Direct drive ignition feature eliminates need for igniter or ignition module, On-board wideband UEGO controller, 6 general-purpose outputs, 7 definable switch inputs, Electronic boost control, Soft cut rev limiters, Two step launch control, Wet or dry nitrous control, Definable knock control, Full idle control, 4 EGT inputs with fuel control, 16/32 hybrid high speed processor
Megasquirt 2
Piggy-Back Units
AEM F/IC
Unichip
SSAFC (Split Second Air Fuel Controler)
Airflow Logistics AFC
