Compare auto reliability with reliable results at TrueDelta.com!
Results 1 to 6 of 6
Thread: Carrier bearing problem = new transmission?
  1. #1
    Registered Member
    Mazdaspeed Protege 2003.5
    Join Date
    Oct 2010
    Location
    Las Vegas, NV
    Posts
    45
    Hey guys. I've been having a whirling/knocking noise ever since I got my MSP. It gets louder and faster as I accelerate, louder and slower as I decelerate, and just loud as I turn right and left. Anyways, I thought it was bad tires, so I changed the tires (they needed to be changed anyway). Noise was still there. Tire Works told me that it was my wheel bearing. Got a 2nd opinion and they said it was my carrier bearing. The 2nd opinion showed me something loose and shaking, right by the transmission and that the "transmission was eating the seal of the carrier bearing" or something like that. I don't understand what is going on. If anyone knows what IS going on please lmk. The 2nd opinion is telling me to just get a used tranny and everything with labor will cost 1500 to 1800 dollars. I just spent 600 on tires. Kill me now.
    I really like the car but this tranny issue is killin me. Everything else is fine with the car but the noise is very annoying! Please HELP!
  2. #2
    2003 MSP# 247 HighSpeed's Avatar
    2003 MazdaSpeed Protege
    Join Date
    Apr 2005
    Location
    Fultondale AL
    Posts
    1,292
    Not every day that you hear of carrier bearings going wrong. Do you know how to test to see if there is any play in the wheel bearings, not saying the carrier bearing is not bad but wheel bearings tend to crap out more often. You may have a diff bearing taking a crap also. Check Mazda for the carrier bearing as I am not sure that a regular parts store carries them. Someone else can confirm this.
    Yeah I can help diagnose your car over the internet.......but its like phone sex.......its better if I'm actually there(upbum)
    03 Black Mica MSP- updated 3-4th gear shift fork, welded lsd, ATP WGA, Spec 2+
    Awaiting my attention: Arias/K1 long rods, SLS motor mount, Boost Science Reflex valve..........more to come
  3. #3
    Registered Member
    Join Date
    Oct 2010
    Location
    Las Vegas, NV
    Posts
    45
    Quote Originally Posted by HighSpeed View Post
    Thanks for replying! I researched on the forum before taking it to get checked. I did try to shake all wheels for any play. No play. I went to Discount Tire, Tire Works, and then the place where I go for oil changes. Discount told me it was my tires and I changed them, Wrong. Tire Works told me it was my wheel bearings, went to the place where I get my oil change and they said they lied and showed me no play on the wheels and then showed me where the carrier bearing is (which is right next to the transmission). Something was loose (which is supposedly the vibration sound) and then some seal in between the carrier bearing and the transmission was broken and looked all tore up. I'll try to get some pics. The sound is getting annoying though
  4. #4
    Join Date
    Apr 2005
    Location
    Fultondale AL
    Posts
    1,292
    Well if its toasted, I would replace it and see if it fixes the problem. If it doesn't I would focus on the cv axles themselves. Good luck
  5. #5
    SELECT * FROM DonutBox 323's Avatar
    (-_-) ...zZzzZzZZ
    Join Date
    Mar 2007
    Location
    VA BEACH, VA
    Posts
    4,657
    super duper bump. did you ever get this issue resolved? just looking for more details. thanks
    03 MSP, 03 P5
  6. #6
    Registered Member Schwamm's Avatar
    2003 Mazdaspeed Protege, 2008 Mazda 3 Hatchback, 1984 RX7 GSL-SE
    Join Date
    Apr 2009
    Location
    Knoxville, TN
    Posts
    171
    Quote Originally Posted by 323 View Post
    Any updates here? Same problem... I'm about out of things that could be wrong and thinking diff/carrier bearing
    2003.5 Mazdaspeed Protege, Laser Blue #2417 - daily driver, almost stock and 145k miles
    2003 Mazdaspeed Protege, Spicy Orange #1496 - saved from the scrapyard - SOLD
    1984 Mazda RX7 GSL-SE
Similar Threads
  1. intermediate shaft carrier bearing??
    By jtlinna in forum Protege5 Lounge
    Last Post: 03-10-2014, 12:54 PM
  2. Wheel bearing problem.
    By kurtis in forum Mazda3 Wheels, Tires, Brakes & Suspension
    Last Post: 07-22-2010, 12:57 AM
  3. Carrier bearing part number.
    Last Post: 03-17-2010, 10:16 AM
  4. '94 infernal frt bearing/hub problem...
    By Multiades in forum Protege Lounge
    Last Post: 03-07-2006, 03:59 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
