Your Best Source for Genuine Mazda Parts!
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: Replaced Alternator and Battery - Still Not Charging
  1. #1
    Doo-Chess H/C/I Stang's Avatar
    2003 MSP
    Join Date
    Jul 2010
    Location
    Seabrook, TX
    Posts
    66
    I recently picked up a MSP with the battery light on. I was told that there was some "cable" that wasn't connected during the engine build.
    Well, the alternator is not charging (tested with a DVOM @ 12.3V with all accessories on at idle.)
    The car died 2-5 times while driving at a very low speed (less than 5mph) with all the accessories on and turning (forcing the power steering to work.) Sometimes, the car wouldn't start if the accessories were on. It would click as if the battery was dead. I've had to push start it the past two starts after sitting for an extended period of time.
    I checked any and all fuses - Good
    I checked the alternator power wire and connections - Good
    Replaced the battery with a new one today.
    Replaced the alternator with a new/reman'd one today.
    Alas, still no charge at idle (12.0-12.3V with all the accessories on.) It shows 13.05-13.1 at idle with only the headlights on (HIDs.)
    What would be causing the light to remain on and still have no charge? I haven't climbed into/under the bay to check for loose wires, but I'm hoping it will be a simple fix. Anyone have any similar issue(s)?
    Always treat your ride like your girlfriend. Tender, loving care along with some wide open throttle.
  2. #2
    Registered Member
    02 P5
    Join Date
    Jun 2006
    Location
    Rockford, IL
    Posts
    1,243
    whered did you get the reman'd alt from? i did this...had to replace my less than a day old reman'd alt with another new reman'd alt. so far its been fine. but the new one i had to replace was only doing 12.25. took it back the next day and it failed the test bench instantly.
    awr front/rear mm 88 duro, twm ss, mazdaspeed struts/eibach prokit, exedy stock replacement clutch/fidanza flywheel, simota cai, header, sls catted midepipe, racing beat catback, mp3 ecu
    My FS thread
    http://www.mazdas247.com/forum/showt...hp?t=123780130
  3. #3
    2003 MSP
    Join Date
    Jul 2010
    Location
    Seabrook, TX
    Posts
    66
    Autozone
    I HOPE that the alternator they sold me is a good one... =\
  4. #4
    Registered Member
    02 P5
    Join Date
    Jun 2006
    Location
    Rockford, IL
    Posts
    1,243
    thats where i bought mine. i bet if you take it back out and have the test it its probably bad. i was told i would probably have to replace it three or four more times til i got a GOOD reman'd one. luckily it took two and ive been good so far.
  5. #5
    2003 MSP
    Join Date
    Jul 2010
    Location
    Seabrook, TX
    Posts
    66
    I'll pull it out and have them test it.
    Maybe get them to order five and check them all before I install any more of theirs...
    Thanks for the hope.
  6. #6
    Registered Member
    02 P5
    Join Date
    Jun 2006
    Location
    Rockford, IL
    Posts
    1,243
    no problem man. trust me i was super pissed that the damn thing didnt even make it a whole day. then i had to drive across town to pick up the closest replacement. i spent like 3 days just working on the damn alt.
  7. #7
    2003 MSP
    Join Date
    Jul 2010
    Location
    Seabrook, TX
    Posts
    66
    Went back up to Autozone and had them test the alternator while it was on the car.
    Same readings I noted when I checked it at my house.
    I pulled the old alternator out of the box and had them bench test it. It passed their machine. Yet, only yesterday, it failed the in car load test. Granted, the in car test was tested at idle and it seemed the bench test was performed at a much higher RPM.
    The man that helped me told me to pull the alternator out they sold me and he would refund my money.
    I take the "new" alternator out, clean the old one (externally with electronics cleaner), sand down the negative battery ground (to transmission) and battery cable terminals.
    I started the car and the battery light was still on.
    I then tested the voltage at idle and recorded a steady 12.71 with the accessories on. I then retested the voltage with the RPMs raised to 2,000, as suggested by certain manufacturers, and recorded a reading of 13.41.
    So, the alternator seems to be charging the battery sufficiently at speed, but not at idle. That problem SEEMS to have been solved.
    Still, the battery light problem evades me. Anyone have any insight on that demon?
  8. #8
    Registered Member
    02 P5
    Join Date
    Jun 2006
    Location
    Rockford, IL
    Posts
    1,243
    You'll get thebattery light because the alt. Is charging... But it should be up at 14-14.5 at idle from the alt. Same problem I had. My new alt was doing the 12 or so at idle and I had the battery light. Switched to the 2nd new alt. And my battery light went away because it is now getting the proper 14 volts. I still recommend you get another new one. The batt light is telling you that it's not getting the proper charge. It will ruin your battery.
  9. #9
    2003 MSP
    Join Date
    Jul 2010
    Location
    Seabrook, TX
    Posts
    66
    I agree. I think the whole, 13.4v at speed is garbage.
    It should be receiving more than that at idle, like every other car.
    I'll go back tomorrow and have a new one put on order.
  10. #10
    Registered Member Tzar177's Avatar
    Donated: $15
    Join Date
    Jul 2005
    Location
    Northern Kentucky
    Posts
    2,803
    An unplugged MAF or IAT sensor will also turn the battery light on. Make sure those things are plugged in...
  11. #11
    mx3ownzj00 low_psi's Avatar
    Donated: $10
    ms|slowtege #399
    Join Date
    Feb 2002
    Location
    Ft. Worth, TX
    Posts
    7,112
    Check the ground cables, specifically the one that goes to the battery itself.
  12. #12
    25ish_psi shane02pro5's Avatar
    Join Date
    Jun 2003
    Location
    Houston, TX
    Posts
    5,009
    Agreed...the battery and alternator are not the only things that can make the batt light stay on. Broken wire at my iat sensor and frayed wire to my cam position sensor in two different instances caused very rough idle and batt and cel light to come on.
    You need to get the cel code read to really know whats going on!
    Quote Originally Posted by Tzar177 View Post
    GT3071R Dual BB 64a/r Steedspeed Mani SpeedCircuit block Arias 8.5:1 Pauter Rods Stage 1 Head AWR oil pan PAR 1-4 Straightcut gearset Haltech F10A J&S Safeguard w Knock Gauge AEM WB Autometer Boost EGT Gauges CS Radiator Walbro GSS342 Fuel Pump Perrin Fuel Rail JoeP FCD Denso Forester 730cc Injectors MSP LSD welded Competition Clutch Stage 5 SS clutchline & brake lines Pope 3" Dp My Custom 3" Boost Activated Cutout Polished Gauge rings Polished Door Sills B&M SS 16oz SS shiftknob Magnacore wires 4awg ground kit Nex Full Coilovers Racing Beat rear sway AWR endlinks DIY Mounts Bronzoil Bushings Redline shiftboot e-brake boot Rota P1 Black 18x8 Yoko S Drives 215/35/18 Sony headunit Sony 1000w 2ch Kenwood 550w 4ch Sony 12" Infinity Reference doors PA 2 farad cap
    FS P5 Rad, P5 OEM Intake , P5 Fans http://www.mazdas247.com/forum/showt...hp?t=123768336
  13. #13
    2003 MSP
    Join Date
    Jul 2010
    Location
    Seabrook, TX
    Posts
    66
    Are the IAT sensor wires blue and orange?
    If so, they're not plugged in and have nowhere to be plugged in. I have a FMIC and it looks like there was never a bung to have one installed.
    Next step?
  14. #14
    Laser Blue MSP #2727
    2003.5 MSP
    Join Date
    Apr 2010
    Location
    Cedar Rapids, IA
    Posts
    835
    Quote Originally Posted by H/C/I Stang View Post
    Next step?
    the IAT being unplugged will not cause a batt light, however bad wires to the IAT will.
  15. #15
    Donated: $15
    Join Date
    Jul 2005
    Location
    Northern Kentucky
    Posts
    2,803
    Next step?
    Yes blue n orange
Similar Threads
  1. Charging dead battery
    By Olestra in forum Mazda3 Audio
    Last Post: 08-27-2008, 06:12 PM
  2. alternator replaced / 65,000miles
    By blatantsilence in forum Protege5 Lounge
    Last Post: 06-15-2008, 08:12 PM
  3. Battery light on? no charging voltage
    By boston73 in forum Protege5 Lounge
    Last Post: 10-26-2007, 04:04 AM
  4. Just replaced alternator...
    By Maz2001MP in forum Protege Performance
    Last Post: 08-12-2006, 10:00 PM
  5. Just replaced alternator...
    Last Post: 07-31-2006, 07:14 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
