Springs, spring rates and drop?
tillyspeed81
Contributor
Mazda5
Just out of curiousity, been thinking of which springs would be best for the 5 and also what their drop and spring rates are.
Does anyone know? (limb) Been thinking if we could list them all here (5 specific and 3 specific as well) it would be a helpful guide for those of us who want to add to their suspensions....
please correct me if I'm wrong and feel free to add more(2thumbs)
For ex:
Stock MS3 springs
drop-1.3F,1.4R
rate- 188F, 171R
Progress(MZ3 and MZ5 specific)
drop-1.4F,1.4R
rate-190F,170R
Tein H-tech (MZ3 specific)
drop-1.4F,1.1R
rate- 146F, 224R
Megan Racing (MZ3 specific)
drop-2"F, 1.9"R
rate-250F, 230R
H&R (for MZ3)
drop-
rate-
H&R (for MZ5)
drop-
rate-
Eibach (MZ3 specific)
drop-
rate-
Cobb (MS3 specific)
drop-
rate-
Great thread and look forward to the details. Any details on the rate of the stock MZ5 springs as well (for reference)?
I know you are still collecting info but consider putting this in a table format.
Also, be good to collect a list of shock/strut and full coilover kits available.
I'm not too good with computers so if someone can make a chart and attach it that would be great.
Couldn't find the stock mz5 spring rates, but found these rates for the mz3 eibachs...
Pro-Kit
(Linear, single rate)
Front = 160#
Rear = 171#
SportLine
(Progressive, Dual rate)
Front = 97# / 280#
Rear = 114# / 303#
__________________
As for some kind of comparison the stock Mz3 spring rates are 150 lbs/in front, 130 lbs/in rear, the 5 should be a little stiffer than that, but can't be for sure til we find the true rates...
mz3 components
also found this on the mz3 forums site, since we can't seem to link on here, I pasted...
these are for the MZ3 but since a lot of us here us the 3 parts, hope this helps...
Coilovers:
H&R
Mazda 3 04+
1.2 - 2.5/0.75 - 2.0
Front & Rear Progressive rate
Non-Adjustable Monotube Inverted shocks
Part # 29197-3
Mazdaspeed3
Part # 29197-6
KW
Mazda 3 04+ Variant 2
30-60/30-60mm
1.2-2.3/1.2-2.3in
DSpring Rates Front= 340/Rear=P
Part No: 15275006
Mazdaspeed3
Variant 1,2,3
Drop .8-2.0in Front & Rear
Spring Rate Front 400/Rear Progressive
Part Numbers:
Variant 1: 10275010
Variant 2: 15275010
Variant 3: 32575010
K-Sport
Rally Spec AR Damper System
Compression/Rebound adjustable
Pillow ball top mount w/ adjustable camber (not available for some models)
Monotube
36-way adjustable dampening
Part # CMZ01-AR
Spring Rates Not given
1600$
Front Mount P/U
Rear Mount ATM
Kontrol Pro Damper System
36 levels of adjustable dampening
Monotube
03-+
Part # - CMZ01-KP
$1,300.00
9/504
5/280
Front Mount P/U
Rear Mount ATM
GT Pro Damper System
Inverted steel shock absorber for durability
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube
03-+
Part # - CMZ01-GT
$1,760.00
9/504
5/280
Front Mount P/U
Rear Mount ATM
Version RR Damper System
Aggressive valving and spring rates
Reinforced internals
Race applications only
Monotube
CMZ01-RR
Bilstein
B16 'PSS9'
Product code: GM5-C126
30-60mm Front and Rear
9-Way Damping Adjustable
allows for adjustable damping in both the compression and rebound cycles
B14 'PSS'
Product # HE5-C122
30mm and 60mm Front and Rear
Monotube inverted technology
JiC
FLT-TAR
Mazda 3 04+
Front & Rear Springs: Linear
Spring Rate: Unkown
Gas Filled Shocks
Product # BK3PFLTA2
BC
Racing Coilovers
Mazda 3 04 +
Front Spring Rate 330
Rear Spring Rate 220
Front & Rear Upper Pillow Ball Mount included
30 Levels of Adjustable Damping
Monotube Shock Design
D2
Mazda 3 04+
Front Rate 9.8kg/mm
Rear Rate 4.6kg/mm
Part # D2-M01
Linear
Dampening Adjustable
Megan Racing
Spring Rate: 8kg Front 10kg Rear
32 Way adjustable valving on front and rear shocks
Part # MR-CDK-M303
Autoexe
Drop: Adjustable
Spring Rate:
Spring Type:
Dampening Adjustable:
Tein
Tein Basic
Drop: Front -.9 to -2.3 , Rear -.4 to -1.6
Spring Rate: 336/392
Spring Type: Linear
Dampening Adjustable: No
SuperStreet
Spring Type: Linear
Dampening Adjustable: Yes
EDFC: Available, part # EDKU1-12120
Shock & Spring Combo (Non-Coilover)
Bilstein
B12 Suspension Kits non coilovers
Product code: SE5-B079
Lowers Front 30mm
Lowers Rear 30mm
Koni
Sport Suspension 1130
Spring by Vogtland
Shock by Koni Yellow
external rebound adjustment
Koni FSD Suspension
Koni FSD shock
Eibach Pro-Kit Spring
Springs & Shocks
Eibach
Mazda 3 04+
Pro-Kit:
Front 1.2 Rear 1.2
Spring Rate: (F) 160 (R) 171
Spring Type: Linear, Single Rate
Sportline Kit:
Front 1.8 Rear 1.8
Spring Rate: (F) 97 - 280 (R) 114 - 303
Spring Type: Progressive, Dual Rate
H&R
Mazda 3 04+
Sport Spring 1.3Front Rear1.2
Part #51643
Mazdaspeed 3 07+
Part #51643-2
K-Sport
Mazda 3 04+
Drop Front 1.3" Rear 1.3"
Part #LSMZ01
Progressive Rate Front & Rear
Vogtland
Lowering Springs
1.6in drop
40mm
Part #958028
Autoexe
Drop: 1.9" front 1.5" rear (not exact; based on pictures and comments)
Spring Rate:
Spring Type:
BG Suspensions
Sport Spring
Drop: Front 1.4in , Rear 1.4in
Spring Rate:
Spring Type:
Part # 50.1.052
Canuck Motorsports
Front Drop: 1.75"
Rear Drop: 1.75"
Spring Rate:
Spring Type:
Goldline
Front Drop: 1.5"
Rear Drop: 1.5"
Spring Rate:
Spring Type:
Part #GPS-1104
Mazdaspeed
Drop: 1.2" (30 mm) front 1.2" (30 mm) rear
Spring Rate:
Spring Type:
Postert
Drop: 1.37"-1.57" front and rear
Spring Rate:
Spring Type:
Intrax
Drop: 1.5" Front & Rear
Spring Rate:
Spring Type:
Part # 45.1.026
Progress
Drop: 1.3" front 1.3" rear
Spring Rate: (F) 190 (R) 170
Part #40.1125
Road Magnet
Front 1.25" Rear 1.25" or Front 1.75" Rear 1.75"
Spring Rate: (F) 310 (R) 360
Skunk2
Drop: 1.5" front 1.3" rear
Spring Rate: 142-208/116-159
Tanabe
Drop: 1.5" front 1.1" rear
Spring Rate:
Spring Type:
Tein
H-Tech
Drop: 1.4" front 0.9" rear
Spring Rate: (F) 150 (R) 220
Spring Type:
S-Tech
Drop: 2.0" front 1.5" rear
Spring Rate: (F) 160 (R) 240
Spring Type:
Sprint
Front Drop: 1.75"
Rear Drop: 1.75"
Spring Rate:
Spring Type:
Part #7530
Megan Racing
Front Drop: 1.5"
Rear Drop: 1.5"
Springs Rate: (F) 250 (R) 230
Spring Type:
Racing Beat
Front Drop: .6"
Rear Drop: .5"
Spring Rate: (F) 151 (R) 143
Spring Type:
Sway Bars
H&R
24mm Adjustable Front (Solid)
Part #70643
26mm Non-Adjustable Rear (Solid)
Part #71643
Urethane/Teflon composite bushings featuring a molded-in fabric-like material that requires no maintenance H&R Sway Bars are powder coated for long lasting performance, quality and beauty.intenance or lubrication, and eliminates squeaking
Eibach
26mm Front (Solid)
Part #5545.310
26mm Rear (Solid)
Part #5545.312
Part # 5545.320 (as pair)
Hotchkis
29mm Front (Hollow)
32mm Adjustable Rear (Hollow)
Part # 22436
95% stiffer than the stock sway bar with a rate of 1625 lbs/in
140% stiffer than the stock sway bar with a rate of 2030 lbs/in
Easy to lubricate polyurethane bushings and heavy duty brackets with zerk fittings included
Progress
22mm Adjustable Rear (Solid)
62.1125
Mazda 3 Stock Bars
Front Bar: 21mm (Solid)
Rear Bar: 20mm (Solid)
Mazdaspeed (Specific for Mazda 3)
21mm Rear (Solid)
Mazdaspeed 3 Stock
Front Bar: 26mm (Solid)
Rear Bar: 26mm (Solid)
Mazdaspeed 3 Aftermarket
F2
Rear Bar: 25 mm (Solid)
Whiteline
22mm rear
22mm front
Auto-exe
Cobb Tuning
Front
1 1/8 Outer Diameter
35% Stiffer than Stock
Rear
1/14 Outer Diameter
50% and 90% Stiffer than Stock (adjustable)
Racing Beat
27mm Rear Adjustable (Hollow)
28.5mm Front
Camber Kits
Eibach / SPC
Part #52.1125
+5.0 to -1.5 of adjustment
Megan Racing
Part # MR-6457
Features Hardened Bushings
Camber Adj Range Not Listed
Mazdaspeed
Non-Adjustable
Braces & Chasis Reinforcement
Mazdaspeed
Front Strut Tower Bar
Part # 143-018-712
GTSpec
Front Strut Brace GTS-SUS-1124
Rear Link Reinforcment Panel GTS-SUS-1127
Rear V-Brace GTS-SUS-1128
4 Points Ladder Brace GTS-SUS-1135
Front Lower Tie Brace GTS-SUS-1125 (3 Only Not Mazspeed3) Member noted that 2.0 Auto only
Rear Lower Tie Brace GTS-SUS-1126
4 Point Brace GTS-SUS-1190
Mid Chasis Brace GTS-SUS-1158 Not app for PZEV
Trunk Reinforcement Brace GTS-SUS-1129
Ultraracing
Front Strut Brace UR-TW2-109 Req modification to fit properly
Front Lower Bar, Front Member Brace UR-LA4-148
Rear Lower Bar, Rear Member Brace UR-RL2-124
Mazdaspeed
Strut Tower Brace
Vibrant
Strut Tower Bar v1 Does not fit sedan models
Endlinks
AWR
Whiteline
Powergrid
kg/mm to lbs/in
16 = 896
15 = 840
14 = 784
13 = 728
12 = 672
11 = 616
10 = 560
9.0 = 504
8.5 = 476
8.0 = 448
7.5 = 420
7.0 = 392
6.5 = 364
6.0 = 336
5.5 = 308
5.0 = 280
4.5 = 252
4.0 = 224
3.0 = 168
2.0 = 112
Are those drop specifically for the 5 or for the 3?
Stock MS3 springs
drop-1.3F,1.4R I know mine is close to 2in without the rubber spacer
rate- 188F, 171R
drop-1.4Fclose to 1.8in on the mazda5,1.4R
rate-190F,170R
