Please read entire post before contacting me. I provide more detailed info about this sub based on some replies below. Thanks
Used for 2 weeks back in 2003 when car was new then I installed a speaker box in the trunk with its own amp and I removed this spare tire sub for simple weight savings as I don't need dead weight in the car. Sub been sitting in a bag in storage since then and is in brand new condition. Direct fit to all 2003.5 proteges5s and maybe the ES sedans also that came with a stock sub inside the spare tire (I'm not 100% sure if the sedans came with subs or not). I have PayPal account and my eBay id is sonicmixmaster with 100% positive rating in other words, I will not screw you on this. I'm asking 55$ + shipping which should not be more than 15$ in the lower 48 states so approx 70$ if shipped or I can make arrangements to pick it up in central/north NJ for 55$. If shipping is more than 20$ I will let you know. Canada shipping is over 35$ so in my opinion its not worth it. What will be sent is the sub with plenty of newspaper packing in a box from a small Lenovo desktop computer, the 8 wire harness plug which I cut off with plenty of room to strip the wires and attach extensions to be hooked up in your car and a piece of paper with description of what each wire is for. 2003.5 models of Protege5 will have a simple plug and play connection and will not need the plug i included. Other cars will need a basic amplifier wiring installation and need +12v from battery and remote wire ran from your radio to the trunk. If your radio has pre-amp outputs (any aftermarket radio does, some stock have it too) you can run those to the trunk also. If your car has standard radio without pre-amp outputs you can use the rear speakers but you will need a high level to low converter. The sub uses low level speaker inputs which are the same wires that the aftermarket radio has marked as pre-amp outputs. On the trunk end those wires will need to have the RCA plugs cut off and bare wires exposed to be connected to the input wires on the amp. Before connecting you will need a volt meter to check which is + and - and match them to the marked + and - on the sub wiring plug i included. All of this may sound complicated but it is the very basic of amplifier installations. If you are local I can help you install it as I'm currently not working and have plenty of time.
NOTE: I don't guarantee that this sub is powerful enough for you. You should understand that this is a original mazda equipment and will perform as a original mazda equipment and this sale is considered as a replacement for your damaged/stolen or whatever spare tire sub. It will add bass to a car that doesnt have a sub and it is sufficient for normal listening.
Just added additional pics <HERE>
