Started off today with my clear third brake light mod. It came out okay but it doesn't light up the full light. I'm going to try something else to try and fix that. If it does work then I'll post a separate DIY.
And, because I'm a glutton for punishment, I replaced the front and rear suspension and sways today. Front wasn't horrible (although the sway was made much easier by having the shocks out). The rear was a different story. Got the coilovers out without much ado, but as the Tokicos are about the diameter of the stock units I had to remove one bolt on each of the rear toe control and upper locating arms (not 100% sure if my nomenclature is right for this car). Even with that the first one was kicking my ass, it kept hanging up on something inside the trunk. Finally got it in, the second one went much better (although I put the bottom on without the washer the first time, DOH!). I'm pretty beat after that so no driving today. I have to make an appointment for an alignment as the car is raised noticeably from the coilovers.
I spent about three hours on the brake light, and 7 on the suspension in total.
