Visit TeamMFactory.com for the best Mazda transmission components!
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: 3rd Brake Light
  1. #1
    Registered Member dfskinner's Avatar
    2006 Mazda 5
    Join Date
    Mar 2008
    Location
    Virginia Beach, Va
    Posts
    115
    3rd Brake Light
    Virginia
    2008 Mazda 5 Sport
    Anyone had to replace or repair the 3rd Brake Light?
    Had my anual inspection today and my 3rd brake light is not working; went to the auto parts store, told me they didn't carry it, called a different store, got the same info.
    Searched the forum but didn't see any info or anyone posting.......
    Thanks in advance for any info
    dfskinner
    dfskinner
    If you don't know where you want to go....
    "Then it doesn't much matter how you get there"
    (2006 Mazada 5)
  2. #2
    Registered Member
    Join Date
    Oct 2005
    Location
    Illinois (U.S.)
    Posts
    715
    Have you tried replacing the bulb?
  3. #3
    2006 Mazda 5
    Join Date
    Mar 2008
    Location
    Virginia Beach, Va
    Posts
    115
    Heat, I hadn't really even looked at it other than to see that two bolts (I think) hold it in place with a plug on the right side behind the cover.
    Are each "LED" a seperate bulb?
    Do you replace the entire strip?
    Anyone have pic's or instructions on how to take the brake light out?
    Instructions on how to replace the brake light? or Repair the light?
    Thanks again for info
    dfskinner
  4. #4
    Zoom-Zoom. Forever. P2K's Avatar
    DBA-BK3P
    Join Date
    Sep 2002
    Location
    El Paso, TX
    Posts
    763
    The led bulbs can't be replaced individually. The entire housing has to be replaced. I was bored one day and took mine out just to see how hard it was to replace. It's fairly simple. Lift the tailgate, remove the cover behind the brake light, unscrew and unplug the brake light, done.
    You only have two options, going through your local dealer or going online through onlinemazdaparts. Here is the website for onlinemazdaparts and they're probably a little cheaper than the dealer. LINK
  5. #5
    2006 Mazda 5
    Join Date
    Mar 2008
    Location
    Virginia Beach, Va
    Posts
    115
    thanks for the info, you're right easy to remove and you can't replace just a bulb; the entire things is sealed except for the fact that my connector. Seems my connector has some rust on it and the bottom post is not connecting or has caused it to short out or blow.
    Stealer ----------------- - $ 154.00
    Link you provided --------- $ 114.50
    Online Junk Yard ---------- $ 45.00
    I'll be calling the junk yard on Monday to ask them to ship
    http://www.car-part.com/
    Last edited by dfskinner; 04-08-2010 at 11:02 PM. Reason: corrected link..........
  6. #6
    DBA-BK3P
    Join Date
    Sep 2002
    Location
    El Paso, TX
    Posts
    763
    Actually it's $89.32 + 6.50 shipping. If the junkyard route doesn't pan out, give them a try. Good luck.
  7. #7
    2006 Mazda 5
    Join Date
    Mar 2008
    Location
    Virginia Beach, Va
    Posts
    115
    thanks, I didn't look far enough to the right........ I'll certainly keep them in mind.....
    thanks again for your help............
  8. #8
    2006 Mazda 5
    Join Date
    Mar 2008
    Location
    Virginia Beach, Va
    Posts
    115
    Received the third brake light from the salvage yard today; took about 5 mins to install, we're back in business, re-inspection tomorrow......... I've also put some silicone on and around the plug to prevent it from rusting out like the old one...... The salvage yard sent the plug and about 6 inches of wiring..... looked almost new........
    If anyone is looking for parts I'd like to suggest you check the online search first; I couldn't believe the savings on just the "3rd brake light"........
    And thanks to everyone on the board for you help........and answering my post........
    dfskinner
    Va Beach
  9. #9
    The sharkfin is in
    Join Date
    May 2006
    Location
    Uxbridge, Ontario
    Posts
    500
    Odds are the issue was the connector. LED's don't blow. they wear out, but a typical LED has a half life of 100,000 hours. IE 100,000 hours until it's half as bright as when new!!! you basicly can;t wear one out in a car break light! corrosion on either the plug or the board is more likely and as the unit is sealed and protected by the wing built into the tailgate I'd say you likely have a leak at the connector. a few minutes cleaning the connector would fix the issue!
    Mods
    Sharkfin Antenna
    Custom 8" sub enclosure
    HID's
  10. #10
    2006 Mazda 5
    Join Date
    Mar 2008
    Location
    Virginia Beach, Va
    Posts
    115
    was98strat, you were right, the connector was bad, but one of the legs on the light was rusted soo bad it broke off when I was trying to clean it..... I've since gone back in and reapplied silicone to make sure this does not happen in the future.......
    Word of advise, if you wash your car a lot, make sure you check for a good seal where the connector and the light come together......
  11. #11
    Registered Member
    2008 Mazda5
    Join Date
    May 2010
    Location
    Omaha, NE
    Posts
    4
    same thing here ... :(
    I am having the same thing. I own my Mazda 5 for a year now and I remember, that about a week after we got it, we went through a car wash and ended up having some water dripping out of the top part of the back door inside the car.
    Well, I just had that power steering recall done at a mazda place and they tell me my third brake light it out. Okay "thanks for letting me know, I'll will fix it", I said. "No. It needs a whole new harness since its bad too and will cost $1800." !!!! WHAT ?!
    I looked at it and the pins from the light rusted away.
    I think, if I just buy a new light I can still use the the connector.
    Thanks for the used car dealer info, I will contact those first.
    johenkel
    __________________________________________________
    2008 Mazda5 Touring
    1995 Mitsubishi Galant SE (sold)
    1994 Jeep Cherokee 4x2
    1989 Olds Cutlass Ciera (sold)
    1983 Golf 1 (RIP)
    1980 Fiat 500 convertible
    1970 Trabant deluxe wagon (RIP)
  12. #12
    Registered Member Sounbwoy's Avatar
    2010 Mazda 5 Sport
    Join Date
    Dec 2010
    Location
    Clayton, NC
    Posts
    256
    FWIW, the 3rd Gen Nissan Maximas had the same issue but with them it was the resistors (capacitor) that usually rusted out. If you have soldering skillz you can replace them with the Radio Shack equivalent and be on ur way..something else to look at with our vehicles...
  13. #13
    Registered Member red headz's Avatar
    Mazda5 GT
    Join Date
    Mar 2009
    Location
    North Tacoma
    Posts
    361
    carpart.com is a good website. I've been referred there several times.
    m.
    '08 Mazda5 GT, Brilliant Black, fog light jumper, MS3 springs, 35% tint, 18" RX8, 16" Protege5
    '00 VW Golf TDI, Satin Silver w/ some real zoom-zoom & burning biodiesel!
  14. #14
    Registered Member
    2008 Mazda5 Touring
    Join Date
    Apr 2010
    Location
    Florida
    Posts
    1,328
    Putting thermal grease or anti-seize onto the connector contacts will help combat corrosion better than anything I've found.
    Aaron
  15. #15
    Registered Member SuperJETT's Avatar
    Join Date
    Sep 2010
    Posts
    182
    Old thread, but same deal here. One of the posts was rusted/broken. We noticed water dripping inside while on vacation and I pulled the light to find that. New on order. I wouldn't buy used for this because it's obviously a design issue due to the frequency so any used one you buy may be close to failing. I'll seal it up before installing the new one once it gets here.
Similar Threads
  1. Brake light doesn't flash when brake pedal pressed
    By goodfornothing in forum Protege5 Lounge
    Last Post: 11-05-2008, 10:39 PM
  2. Replies: 6
    Last Post: 07-13-2008, 10:05 AM
  3. Emergency brake (hand brake) light problem
    By mtarajia in forum MS3 Lounge
    Last Post: 05-15-2007, 04:15 PM
  4. E-brake light turns on when i brake...
    By NinjaSYXX in forum Protege5 Lounge
    Last Post: 01-12-2007, 10:57 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
