Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 2 of 2
Thread: How to disable factory alarm?
  1. #1
    HID Guru
    2002 Mazda Protege5
    Join Date
    Aug 2009
    Location
    US
    Posts
    3,308
    After unplugging my battery terminal again I can't stop my alarm
    from going off once the battery is plugged in and I've tried everything but to no avail. Is there a way to permanently turn it off?
  2. #2
    Registered Member AusOrion's Avatar
    Mazda SP20 sedan (MP3)
    Join Date
    Jan 2007
    Location
    Brisbane, Australia
    Posts
    473
    Quote Originally Posted by Matt V View Post
    Sounds like you have an upgraded spec factory alarm like mine. I will tell you what I know about my alarm and it might help you get yours sorted.
    There is a large capacitor in the siren that will run for about 20-30 minutes depending on its age. And the bad part is that it only takes about 30 seconds to fully recharge.
    Thankfully mine has kinda packed it in and will sream for about 30 seconds before it runs out of juice.
    About 4-5 inches from the siren (heading towards to the headlight) there is a connector under all of the electrical tape that I guessing is there. If you disconnect that and let the siren drain the capacitor on its own then you shouldn't have any problems in the future. Throw some blankets or towels on the siren, close the hood and grab a beer or two while you wait for the siren to run flat.
    My ultimate goal would be to have a second connector sticking out of the electical tape that I could plug a small 12v battery to while I disconnect my car battery.
    Cheers.
Similar Threads
  1. how to disable factory alarm on protege??
    By Huascar82 in forum Mazda Tech & How-To
    Last Post: 01-13-2007, 02:38 PM
  2. Replies: 3
    Last Post: 07-24-2006, 11:52 PM
  3. Replies: 16
    Last Post: 02-17-2006, 02:57 PM
  4. Disable Alarm horn Chirp
    By jerome8283 in forum Other Lounge
    Last Post: 10-17-2004, 08:53 AM
  5. Factory alarm problem after new alarm install
    By slenser in forum Mazda Tech & How-To
    Last Post: 07-01-2003, 06:34 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
