Your Best Source for Genuine Mazda Parts!
Results 1 to 4 of 4
Thread: BTN Fuse Blowing
  1. #1
    Registered Member duffbuster243's Avatar
    Join Date
    May 2007
    Location
    Scranton, PA
    Posts
    305
    BTN Fuse Blowing
    I have a slight problem with my MSP. I started the car today and it was fine but the radio wasn't working. I shut it off figuring if I turn it back on the radio might work. After shutting it off I tried to start it back up and there was nothing, the starter wasn't getting any power. I managed to get it started by rolling it and popping the clutch and it ran fine. I checked the fuses and all were good except the BTN fuse under the hood. It is a 40a fuse. I tried a new one only to have it instantly blow again. Right now the radio doesnt work and the alarm doesnt work. I know there has to be a short somewhere. I would like to know if anyone has had a similar problem or if anyone knows exactly what electronics are connected to this fuse so that I can remove them one by one to find my short?
    Lazer Blue MSP #2500 Sold
    2002 Sunlight Silver Protege5 Auto Sold
    1990 White Turbocharged Miata
    2006 Titanium Mazda3s
    2003 Blazing Yellow MSP #249
  2. #2
    cheif smacktalker yudkib's Avatar
    Join Date
    Mar 2009
    Location
    hartford ct
    Posts
    4,604
    im guessing you have to pull the car apart. that sucks, because with a blown fuse you cant even use a multimeter to make things a little easier.
    maybe you could take it to a pro and get a quote, id imagine they want like 120 to fix that, but it might be worth it.
    titanium #129 - sold.
    "What do I think of success? It sucks, too much press, I'm stressed - Too much stares, two breasts, too upset. It's just too much mess. I guess I musta blew up quick, grew up quick, was raised right. Whatever you say is wrong, whatever I say is right"
  3. #3
    Join Date
    May 2007
    Location
    Scranton, PA
    Posts
    305
    I found the problem, the rear window defroster must be bad and is blowing the fuse. Just figured I would post in case anyone else ever runs into the problem in the future.
  4. #4
    Join Date
    Mar 2009
    Location
    hartford ct
    Posts
    4,604
    wow, howd you figure that out?
Similar Threads
  1. HID kit blowing my fog fuse....
    By LReyes66 in forum Mazda3 Audio
    Last Post: 07-16-2008, 09:53 AM
  2. fuse f69 keeps blowing
    By riccitelli in forum MS3 Engine & Transmission
    Last Post: 04-24-2008, 10:03 PM
  3. fuse keeps blowing
    By Andrewsmc in forum MSP Audio
    Last Post: 07-18-2007, 09:14 PM
  4. Help! Blowing Fi Fuse
    By CBIGGS in forum Protege5 Lounge
    Last Post: 10-12-2006, 09:09 AM
  5. Fuse blowing
    By Fade in forum Protege5 Lounge
    Last Post: 06-30-2005, 12:31 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
