Updated 3/6/15 @ 139K:
- Oil consumption issue
http://www.mazdas247.com/forum/show...Build-Thread&p=6364761&viewfull=1#post6364761
Updated 12/1/14 @ 133K:
- Michelin AS/3 Update
- KW Coilover Update
- Ambient Temp Issue
- Oil Cooler Issue
http://www.mazdas247.com/forum/show...Build-Thread&p=6345786&viewfull=1#post6345786
Updated 5/21/14 @ 120K:
- Maintenance
- Audio and Android Integration
http://www.mazdas247.com/forum/show...Build-Thread&p=6296924&viewfull=1#post6296924
Updated 8/30/13 @ 103K:
- AC Compressor issue
http://www.mazdas247.com/forum/show...Build-Thread&p=6210544&viewfull=1#post6210544
Updated 1/25/13 @ 89K:
- Maintenance
- Tires
- Bose Upgrade
http://www.mazdas247.com/forum/show...Build-Thread&p=6103845&viewfull=1#post6103845
Updated 12/20/10 @ 45K:
- MSCAI Filter Cleaning (complete with near-disaster)
- Corksport Inserts
- H&R Coilover Update
- Hankook Ventus V12 Evo Update
http://www.mazdas247.com/forum/show...Build-Thread&p=5540419&viewfull=1#post5540419
Updated 8/20/10 @ 37K:
- Powergrid Adjustable Endlinks
- CPE Rear Motor Mount
http://www.mazdas247.com/forum/showpost.php?p=5412645&postcount=18
Updated 7/5/10 @ 33K:
- H&R Coilovers - the good and the bad
- Cabin Air Filter
- Hankook Ventus V12 Evo K110 Tires
http://www.mazdas247.com/forum/showpost.php?p=5342597&postcount=16
Model: 2009 CWP MS3 GT, purchased Jan 2009
Current mileage: 24,875
Mods:
-Rear bumper guards
-Wheel locks
-Ventureshield Clear Bra
-OEM iPod integration unit
-MSCAI
Premise
After seeing so many questions raised about MS3 reliability & maintenance, I thought I'd start a running log regarding my ownership of the MS3. I will update this thread every so often - kind of like a blog I guess - to give others an idea of your typical ownership experience. Unlike many, I plan to keep this car until the wheels fall off or family priorities dictate otherwise. Hope this proves useful to prospective buyers and fellow owners.
Maintenance/Reliability
After owning this car a year I can say it's been a worry-free DD. I've only had one warranty claim for the squeaky seat belt bolts. Beyond that, a few minor ticks/rattles from the console due to the nearly worn Bridgestone RE50's. Front passenger carpet separates from the plastic trim over time as people enter/exit the car. Also have an intermittent tick from the engine bay which only appears at certain RPMs. If I can isolate the noise, I'll probably have the dealer take a look. All of these things are more annoying than an actual problem.
Senior tech at the dealer (Tuttle Click Mazda of Irvine) seems to know his stuff and is always open to share his views on what goes wrong on these cars. Ironically, he sees very few Speeds in for warranty work, whether approved or denied. Biggest issue has been the HU, which was sourced through a new vendor starting in 08.5. Beyond that, one or two turbos from earlier models, a seized belt buckle, and a few other minor odds & ends.
I have the oil changed every 3,700 miles using whatever run-of-the-mill brand was chosen by the dealer. Get charged $26.00 for oil, rotation (every 7500), and basic inspection. Car is treated with respect around the service bay. Service Manager is a down to earth guy. Their stand on warranty claims is like most other Service Managers I've spoken with; change the oil and filters at the designated intervals and you're fine. They don't really pay attention to aftermarket parts unless they're excessive or a failure appears to be connected to a mod.
Mods
The clear bra was installed 7 days after getting the car and has been one of the best investments to date. I get a little dirt around the edges but nothing that can't be cleaned with a toothpick. Lifetime warranty on materials/installation, and the installer has offered to come back anytime to touch up the film as needed. I've had a few nasty high speed impacts, but the film has remained resillient. One small puncture about 1" wide from a sharp object at 70 mph. Everything else has buffed out with some clear wax and a little pressure.
Rear scuff guards were purchased in January 09 and have saved my butt more than once taking things in and out of the hatch. OEM iPod interface was purchased in March 09. It works well, though it sometimes shows a mismatch on the text display between the displayed artist/song and what is actually playing. Only happens when I hit the RDM function. MSCAI was purchased in May 09 and added 27 HP at the hubs (as measured by a Dynapack). As many others have said, car holds power all the way to 6K. I've had a couple issues with fuel cut/hesitation, but they are few and far between. I run the air straightener at a 45* angle as recommended by Mazda.
Driving Experience
Overall, this car is just as fun now as it was the first day I got it. I am slightly annoyed by the front end float, underdamped rear suspension, non-linear clutch engagement, and somewhat mysterious shifter at WOT. First two problems will be fixed next month with a decent coilover suspension. I might eventually replace the tranny mount like many others have done, but for now the vague shifts at WOT are liveable.
Car is predictable in the turns, though a bit unsettling at its limits. I suspect some of this has to do with the design of the rear suspension. The rear bump stops are apparently progressive and help to simulate a rapid increase in spring rate. So the initial contact with the stopper is very soft, but rapidly becomes stiff as you apply more pressure. So if you're on the stopper in a hard corner and hit a small bump, you'll get some unexpected wheel hop. I suspect with better rear dampers the car would react better to this type of condition. Wife feels the stock suspension is slightly annoying, but liveabe.
Everyone who has ridden in this car has commented on the interior design/quality. Alecantra trim is holding up well with no signs of premature wear. Seats are well bolstered yet surprisingly comfy - even on 8+ hour trips. Car is great for hauling just about anything, from groceries to flat screen TV's. Exhaust note is pronounced but not overpowering IMO.
Bose system is not horrible, but not great either. Highs and lows are puposely cut by the signal processor (I suspect to promote longer speaker life). CD changer works great, though a bit slow with MP3's. The Aux input restricts the signal somewhat which is one of the reasons I got the iPod adapter. Unlike some, my auto wipers work fine. I have sensitivity set in the middle.
That's it for now. Next update will be after I install the coilovers. Thanks for reading!
- Oil Cooler Issue
- Maintenance
- Maintenance
- Tires
- Bose Upgrade
- Corksport Inserts
- Cabin Air Filter
Mods:
-Rear bumper guards
-Wheel locks
-MSCAI
Premise
Mods
Driving Experience
