In Memory of Mazdas247 Member "1338"
Results 1 to 2 of 2
Thread: Airbag light and related code finally fixed
  1. #1
    Over this past Summer, I did a collision restoration on a 2005 Mazda 3i 2.0. Along with replacing the driver's airbag, and I had the SRS module reset. The airbag light turned off, as promised by the company who reset the module. Unfortunately, however, the airbag light came back on about a week or two later. I had the airbag codes pulled, and code B1890 came up, which is "Passenger Airbag Deactivation ("PAD") lamp shorted to battery".
    After checking the related electrical circuits and fuses, I figured that the module was at fault. I returned the module to the same company, and they cleared all of the codes again at no charge. After installing the module, the airbag light turned off for about a week. Then it turned on again. At this point, I was getting very frustrated. The company who reset my module recommended that I replace the PAD lamp holder. The bulb holder is such a simple connector that I almost disregarded the advice. However, I hit the local salvage yards today and brought one home. Here's the main point of the story: I noticed that the bulb in the holder from today is 5W; I've been using a 7W bulb, as most posts say that the PAD lamp bulb is the same as that of the glove box and trunk. I inserted the 5W bulb into the bulb holder, and it turned off my airbag light. Hopefully, this post will help those of you with the same airbag code.
  2. #2
    Well done I told you I'd reply to this
Similar Threads
  1. Airbag code #22?
    By tms217 in forum Protege Performance
    Last Post: 12-08-2009, 09:47 AM
  2. airbag code 34
    By meackerman in forum Mazda5 Car Audio & Electronics
    Last Post: 09-27-2008, 11:11 AM
  3. Airbag Code?
    By dnale in forum Mazda Protege 5 (Protege5.com)
    Last Post: 03-06-2008, 09:15 AM
  4. Eratic idle and cel code 171 fixed.
    By mazdaspeed/se-r in forum MSP Engine, Performance & Forced Induction
    Last Post: 04-18-2006, 08:53 PM
  5. How are dealers handling brakes/airbag light/engine code?
    By eting_pro5 in forum MAZDASPEED3 Forum
    Last Post: 07-20-2004, 05:31 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
