VersaTuner - tuning software for Mazdas
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: pulling to the right. not alignment...
  1. #1
    Registered Member reut1's Avatar
    2003 Protege5, 1992 Miata
    Join Date
    Jul 2009
    Location
    Seattle, WA
    Posts
    2,105
    hey all
    ive noticed for a bit that my car has been pulling to the right, especially noticable when on the highway. when the wheel was held straight the car would pull to the right even more. also when i had a friends wheels on my car, the drivers side front wore real weird after having them on for about 1-2k miles.
    so today i went in for an alignment, they did all 4 wheels. not a big adjustment apparently since most things were fairly straight they said. when steering wheel is held straight the car goes straight but will still pull kinda hard to the right, especially while accelerating.
    anyone elses car pull when accelerating?
    i have a printout of the previous and current specs on the car which i can try to scan in and post later on. or ill snap a picture of it
  2. #2
    Registered Member civickilla03's Avatar
    Join Date
    Aug 2007
    Location
    Charlotte, NC, USA
    Posts
    1,980
    same same
    i have his same problem but to the left, if i dont hold the wheel at a slight angle it will just pull by itself.
    interested in this
  3. #3
    HID Guru
    2002 Mazda Protege5
    Join Date
    Aug 2009
    Location
    US
    Posts
    3,308
    Rotate your tires then go from there. Your tires could be worn unevenly.
  4. #4
    Riddle me that! slavrenz's Avatar
    2001 Mazda Protege LX 2.0
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    Quote Originally Posted by matt v View Post
    rotate your tires then go from there. Your tires could be worn unevenly.
    +1. Switch your front tires to see if the pull follows the tire.
  5. #5
    Registered Member
    Join Date
    Dec 2009
    Posts
    20
    I had the same prob and it still pulls to the right a bit. I will be fixing it sometime soon. However, before alignment, I would suggest looking at the struts caster and camber for any bents or damage. If you dont look at this and do the alignment, you'll have to duplicate the alignment job and that's more $$ out the door.
  6. #6
    Registered Member pasadena_commut's Avatar
    Protege5 2003
    Join Date
    Oct 2005
    Location
    Arcadia, CA
    Posts
    1,178
    Quote Originally Posted by the_mgroove View Post
    That sentence is bent and damaged. Please straighten it so that we can understand what you meant.
  7. #7
    Registered Member
    2002 Protege5
    Join Date
    Dec 2007
    Location
    Decatur IL
    Posts
    680
    Are you sure it isn't just torque steer? I've never really noticed a pull from the anemic 2 liter, but have never really taken my hands off the wheel while accelerating.
    02 Protege5 - Vivid Yellow - 245K mi
    flywheel, clutch, UR pulley, Injen, OBX, MagnaFlow, Hella fogs, Pioneer head, sub, & 6x9s. On my 7th Mazda!
  8. #8
    Registered Member
    Join Date
    Dec 2009
    Posts
    20
    Quote Originally Posted by pasadena_commut View Post
    oops. that's strut caster and camber.
  9. #9
    Join Date
    Jul 2009
    Location
    Seattle, WA
    Posts
    2,105
    could be just torque steer still. i know there was some odd wear on the one tire of my friends since he had i guess to say a "standard" type tire (rails running all way around) where i have kinda an "arrow head" treat so its harder to tell wear.
    forgive me for my tire terminology, hehe.
    here are pics of my before and after specs on the alignment, if it means anything to anyone to help with this.
  10. #10
    Registered Member jr10000's Avatar
    Join Date
    Jul 2009
    Posts
    14
    I have the exact same problem.. pulls to the right. I took it in for an alignment and it still did it. but when i got new tires they said my rim was bent beyond belief and i asked them could that make my car pull and they said yes. But i just dont have the money right now to buy new rims.
  11. #11
    Registered Member Tukalama's Avatar
    2011 Mazda 3i Touring
    Join Date
    Oct 2008
    Location
    Monessen, Pa
    Posts
    271
    Quote Originally Posted by jr10000 View Post
    I had this problem as well. I replaced the bad rims (1 really bad, 1 slight) and the problem was gone.
  12. #12
    Registered Member
    Join Date
    Mar 2009
    Posts
    243
    Whoever did your alignment is awful.
    Anyways, I've heard a lot of problems about the p5 pulling to the right.
    Highway pulling isn't torque steer btw, you would know if it was haha it's awful!
    Rumor has it there was a bulletin out to the dealers about ways to fix the pulling issue, but I can't say if that's your issue or not. I'd start with crossing the front tires.
  13. #13
    Join Date
    Jul 2009
    Location
    Seattle, WA
    Posts
    2,105
    the alignment specs are really off now? town fair tire did it, a tire chain throughout ct, ny, ma, ri, and nh. ive got a 30 day warranty on it if i want them to redo it.
    i will try rotating. maybe i can have them check to see if any rims are bent, if they will do it for free.
  14. #14
    Registered Member
    2008 Mazda 3i 4 dr Touring Value Edition
    Join Date
    Jul 2008
    Location
    Asheboro, NC
    Posts
    599
    Quote Originally Posted by reut1 View Post
    I don't see where the alignment specs are off. The before and after read outs are all within the shop manual specifications.
    It would be better if the front and rear camber side to side reading are closer. A small camber change can be made by rotating the upper strut mounts but not enough to help. It's sometimes possible to change camber by loosening the lower strut mounts with the wheel off the floor and allow the assembly to shift (the bolt holes have a little play) and retighten. That usually will not correct a pull, it's more for tire wear.
    I have experienced steering pull on some other cars and it's usually the tires. The easy check for that is to switch the tires from side to side as has already been suggested two times. I don't think a bent wheel will normally cause a pull it will usually cause a wobble and perhaps vibration or steering shake.
    Clifton
  15. #15
    Join Date
    Jul 2009
    Location
    Seattle, WA
    Posts
    2,105
    kind of sucks that i paid to find out the alignment really wasnt off but its alright. paid for a front wheel alignment and i got an all around one. i cant rotate the tires from side to side due to being unidirectional but i will change the front to back later on to see.
    there is steering shake, not a ton but its noticable. ill try to get my wheels checked out. i gave one of my old mismatching ones to someone and he said it was bent when he got it balanced so i dont doubt that others are like that. maybe new wheels in the spring instead of lowering the car!
Similar Threads
  1. Car not pulling
    By bradboyd80 in forum MSP Problems
    Last Post: 07-26-2009, 02:07 PM
  2. Pulling to the right
    By cpspeed6 in forum Mazda6 Wheels, Tires, Brakes & Suspension
    Last Post: 07-02-2009, 12:44 AM
  3. MP5 pulling
    By SlamminRIde in forum Protege5 Lounge
    Last Post: 04-23-2009, 06:23 PM
  4. Alignment inquiry: P5 on H&R springs - should I get MSP alignment specs?
    By Dimitrios in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 06-08-2008, 07:45 AM
  5. Still Pulling Right After Alignment
    By carter1551 in forum Protege5 Lounge
    Last Post: 09-29-2007, 04:14 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
