Just want to start by sayin high and im new to this forum This car has me puzzled has no engine codes has spark fuel pressure within spec injector ohm reading within spec crank shaft sensor ohms within spec timing belt still on corrrect marks what is weird is if i hold the accelerator to the floor it will almost start and it does this with the camshaft position sensor plugged in and not plugged in but the ohms check out on it also i dont think it is the ecm because it dont think i would still get the spark and it almost startin with the acc pedal down any help would be greatly appreciated
