Your Best Source for Genuine Mazda Parts!
Results 1 to 11 of 11
Thread: Low tone horn added to factory high tone horn
  1. #1
    Registered Member MS3Steve's Avatar
    07 Mazdaspeed 3 GT
    Join Date
    Feb 2008
    Location
    Cincinnati,OH
    Posts
    79
    I'm off work this week (unpaid!) so I have some extra time and was in the mood for a car project. I remember seeing a thread about adding in a low tone horn to our cars, but after searching all I could find was a youtube clip about it. After watching the clip I went to autozone and for $17 bought a low tone horn. It is very easy to install, the only hard part is taking off your bumper. I had taken my bumper off once before for my CAI install, so I wasnít as hesitate about doing it again.
    What I canít get over is right next to our factory horn there is a threaded hole that the low horn mounts perfectly into. Why didnít Mazda just put one there! Anyways, here are some pictures and clips of before and after, let me know if you have any questions. Thanks to retrobmx63 for posting the youtube video.
    Factory horn
    Horn before
    Low tone horn added
    Horn after
  2. #2
    Zach Sport6's Avatar
    2009 Subaru WRX Sedan
    Join Date
    Dec 2007
    Location
    Ashburnham, MA
    Posts
    3,135
    Good job, I have to get around to this sometime soon. How did you secure the low tone in there? I know you said there is a spot but does the low tone come with a bracket? Is the picture you posted of it already secured into place?
    Traded....
  3. #3
    07 Mazdaspeed 3 GT
    Join Date
    Feb 2008
    Location
    Cincinnati,OH
    Posts
    79
    Thanks Sport6, I should have taken a few more pictures, but if you look closely in the first pic that black bracket to the right of the stock horn has a hole at the bottom that is threaded. The new horn has a threaded stud on it, so all you do is screw the horn assembly into the existing hole. The threads match up perfectly and it makes for a tight fit. After that I just tapped into the postive wire going to the stock horn and grounded the other terminal and it worked! The only thing I wish I did was test to see what just the low tone horn sounded like, ill have to try it when I clean my air filter next.
  4. #4
    Registered Member Darth Vader's Avatar
    Join Date
    Apr 2009
    Location
    Vancouver
    Posts
    1,088
    I was able to drill a hole in the stock arm and mount the low tone above the high tone. It's a tight squeeze with the CAI in there but it did work. Removing the horn and arm isn't hard, pull the front of the splash shield, fish an arm with a 12 mm wrench up there and undo the one bolt holding it on.
    this combo make an old-school American car horn sound. It's a huge improvement over the stock meep-meep chick-car sound.
  5. #5
    Registered Member
    2008.5 Mazda 3s GT manual
    Join Date
    Sep 2009
    Location
    Tampa, FL
    Posts
    25
    sorry this is a bit off topic, but your CAI has a shield (looks like the mazdaspeed CAI). Does everyone mount them like that with the shield facing up? or is it possible to flip it upside down to reduce water from splash/tires?
  6. #6
    Join Date
    Dec 2007
    Location
    Ashburnham, MA
    Posts
    3,135
    Great, I see that hole now, Thanks! Ya I wonder what two low tones sound like (or 1)?
  7. #7
    Speed3 & TWO Hemis MikeHTally's Avatar
    2008.5 Speed3, 2006 Chrysler 300C, 2003 Ram 1500
    Join Date
    May 2008
    Location
    N. Florida
    Posts
    2,085
    It isn't necessary to remove the bumper. I went in through the flap in front of the wheel. I used the Wolo air horn and added a small bracket to the existing one. Had to add a relay triggered by the OEM horn's power. Works well and definitely gets their attention.
    2008 1/2 CWP GT
    ______________
    Wolo Air Horn
    Cobb SRI/Forge BPV
    15% tint/Vent Shades
    Center Brake Light Flasher
    Redline Tuning Hood Springs
    Cobb RSB/CorkSport MM inserts
    Spin-on filter conversion/Quick Oil Drain Valve
    RX-8 wheels/Painted Calipers/Continental Extreme Contact DWS
  8. #8
    07 Mazdaspeed 3 GT
    Join Date
    Feb 2008
    Location
    Cincinnati,OH
    Posts
    79
    Quote Originally Posted by kjohn View Post
    No problem about being off topic, you are right I have the Mazdaspeed CAI. I'm pretty sure I mounted the shield that way per the instructions. The shield has two mounting holes that line up with a bracket on the lower intake tube. I remember debating how to mount it and if I recall it only mounted one way. I think the plastic splash guard covers the filter from the bottom and the shield protects the other sides. If I have it backwards please let me know?!?!
  9. #9
    Registered Member
    Join Date
    Sep 2009
    Location
    Tampa, FL
    Posts
    25
    I was only asking because I am currently researching CAIs and debating which one to get, but I dont which way it goes
  10. #10
    8ANNED NiteRunner's Avatar
    MazdaSpeed3 GT
    Join Date
    Jun 2008
    Location
    Ft Lauderdale, FL
    Posts
    104
    Quote Originally Posted by Sport6 View Post
    One low tone sounds just as pathetic as one high; two of either are barely an improvement. To those who have done it, the hi/low is night and day difference.
    I think my low tone came with a small bracket, I just bolted both horns to the same hole on the stock bracket and went in through the bottom. Small spot to get your arms in to say the least.
    Also, has anyone mentioned the clip that attaches the wire to stock horn?
    Major PITA but I think the correct way to remove it is to "press" the little flappy plastic thing "in" to release the horn. It feels like you should "lift up" on it, but that does nothing.
    I'm getting racing headlight fluid next!
    08.5 True Red MS3 155MPH
    01 Blu/Silv Hayabusa 197MPH
  11. #11
    Registered Member araw at bituin's Avatar
    Join Date
    May 2010
    Location
    Scottsdale, Arizona
    Posts
    167
    Quote Originally Posted by maryflint View Post
    I really dont like the sound of my stock car air horn. I am planning to change it next year, may I ask for some brands which are ok for replacement? thanks.
    the stock horn is a fiamm i believe. so just add a low tone fiamm to your stock horn and it'll sound great. that's what i did.
Similar Threads
  1. Two tone MS3?
    By Element in forum MS3 Lounge
    Last Post: 07-14-2009, 02:52 PM
  2. Installed low tone horn - Video
    By Retrobmx63 in forum Mazda3 Audio
    Last Post: 05-20-2009, 03:08 PM
  3. Factory Alarm - Can Horn be Replaced by Siren?
    By SVOGT in forum Mazda6 Audio
    Last Post: 01-08-2006, 03:21 PM
  4. Two Tone Help
    By BacDoc in forum Protege Appearance
    Last Post: 04-05-2003, 04:02 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
