CheeseHelmet
I just got a OBDII scanner yesterday and I hooked it up to my PR5; it had one DTC code: P0660. The service manual says "VICS solenoid valve circuit malfunction".
I checked out the solenoid this morning and sure enough there's no continuity across it. The DTC doesn't cause the MIL to turn on so I assume it's not that serious but if something's broken I'd like to fix it
So, how important is that solenoid? From what I've read, VICS is the system that manages those butterfly valves in the air intake, so does that mean that they're permanently open/closed without that solenoid?
Perhaps someone could clarify how the VICS system works in conjunction with the VTCS system, I can't really tell the difference between the two...
