- 2022 CX-5 Turbo
Found this in my WorkShop manual today.
Seems like someone would be interested in. So here it goes.
This is apparently for people who think their CX9's auto-headlights are too sensitive and want to dumb it down a bit (to low-sensitivity)....
(proceed at your own risk)
AUTO LIGHT ILLUMINATION SETTING
Without Using M-MDS
Caustion:
- If any of the following occurs, the sensitivity cannot be set properly. Therefore, resume from Step 1.
- Each procedure and operation interval exceeds 5 s.
- Procedures are performed incorrectly
Note:
- Perform the procedure in a condition that allows verification of the headlight illumination because it is necessary to verify the setting condition according to the number of times headlights turn on
#1: Turn the ignition switch to the ON position with the light switch in the OFF position and pulled back (Flash-to-pass ON)
#2: Switch the light switch from OFF to TNS position five times and return it to the OFF position
#3: Pull the light switch back once (Flash-to-pass ON)
#4: Turn the light switch to the TNS position
#5: Switch the light switch from the TNS to ON position five times and return it to the TNS position
#6: Turn the light switch to the ON position
#7: Switch the light switch from the ON position to AUTO position five times and return it to the ON position
#8: Turn the light switch to TNS position
Note:
- Switches to the sensitivity setting mode when the above operations are performed
- The headlights turn on for the number of times according to the current setting conditions
> Illumination (Two times): Standard sensitivity
> Illumination (Three times): Low sensitivity
#9: Switch the sensitivity by pulling the light switch back (Flash-to-pass ON)
#10: Verify the number of times the headlights turn on and that the sensitivity is set properly
- Illumination (Two times): standard sensitivity
- Illumination (Three times): low sensitivity
Without Using M-MDS
Caustion:
Note:
Note:
