Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 9 of 9
Thread: How to fix P0443 engine code?
  1. #1
    Registered Member
    Join Date
    Jul 2009
    Posts
    7
    Its related to Evaporative Emission control system purge valve circuit. The car seems to be running ok though. The light has been on for approx 7 days now, I finally bought a scanner today.
  2. #2
    Registered Member
    Join Date
    Jul 2009
    Posts
    7
    Actually this scanner shows:
    p0443
    p0505
    p0123
    p0118
    p0113
    Things seem to be running ok though. I'm not sure what all these sensors mean though and how to fix them. I assume I shouldn't just clear them...
  3. #3
    MSP Chick :) Metallic36's Avatar
    2003 Mazda6 3.0L Speed Yellow
    Join Date
    Jul 2006
    Location
    Lula, GA
    Posts
    3,141
    Go to the Search button on here, type in each code, and you will find various threads in regards to the code you entered. You probably need to do a bit of research before just deleting the codes, they're not there for nothing despite your car running okay.
  4. #4
    Join Date
    Jul 2006
    Location
    Lula, GA
    Posts
    3,141
    p0443 - Purge Circuit Malfunction
    p0505 - Idle Control System Malfunction
    p0123 - Throttle Position Sensor/Switch A Circuit High Input
    p0118 - Engine Coolant Temperature Circuit High Input
    p0113 - Intake Air Temperature Circuit High Input
    Nevermind.. did it for you.
  5. #5
    Riddle me that! slavrenz's Avatar
    2001 Mazda Protege LX 2.0
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    Quote Originally Posted by maggio View Post
    Your purge solenoid valve is likely bad. It's the little thing that sits on top of your intake tube with the two vacuum hoses going into it. Disconnect the connector and measure the resistance between the two metal terminals. If not between 22-26 ohms, it needs to be replaced. The part number is B66S-18-740, and it retails at onlinemazdaparts.com for about $67.
    Post back here with results.
  6. #6
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    Quote Originally Posted by Metallic36 View Post
    Ignore what I previously said - it always takes me so goddamn long to write a response that people post up new info .
    You need to get underneath the hood and check for some serious wire damage or else a bunch of stuff that's unplugged. My guess is that something somehow got fried and is causing all of these sensors to short circuit. These is no reason that they should all be malfunctioning at the same time.
    You need to be checking on the driver side of your engine around the throttle body and battery - that's where all of this stuff is located.
  7. #7
    Registered Member
    Join Date
    Dec 2009
    Posts
    1
    Hi,I'm having problem with DTC PO443 on 01 mazda 626.
  8. #8
    Registered Member
    mazda 2003 tribute
    Join Date
    Nov 2011
    Location
    tucson
    Posts
    1
    i have a po443 code on a 2003 mazda tribute what is the problem
    and have a battery light stay on
  9. #9
    Registered Member tweety2300's Avatar
    2001 mazda protege mp3
    Join Date
    Sep 2010
    Location
    virginia
    Posts
    5,806
    If your battery light is on your alt is bad
    Also this section is for proteges btw post in the tribute section. Welcome to the forum either way
Similar Threads
  1. Help, DTC code P0443
    By ISELLSPEED in forum Mazda6 Engine & Transmission
    Last Post: 07-21-2009, 01:25 PM
  2. engine code / mazdaspeed3 engine swap?
    By shad0wsfall7 in forum MS3 Engine & Transmission
    Last Post: 10-22-2007, 07:16 PM
  3. Engine Code
    By Lord_Nycon in forum MS3 Engine & Transmission
    Last Post: 04-14-2005, 03:36 AM
  4. What is the Engine code for the 2.3L
    By crayz_d in forum Mazda6 Lounge
    Last Post: 03-21-2003, 01:26 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
