Your source for Mazda shift boots from Redline Goods!
Results 1 to 12 of 12
Thread: What spark plugs should i get???
  1. #1
    Spicy Speed
    03 MSP
    Join Date
    Aug 2009
    Location
    Ft. Walton Beach
    Posts
    3
    Items for Sale
    Alright, its time for some new plugs on my 03 msp and i was wondering what plugs i should run. i run stock boost and have a tb exhaust, CAI, performance exhaust mani. all other mods are in drivetrain. I also want to change my gear oil. what should i use, and is there a specific weight i should be looking for. Any help would be awsome. Thanks
  2. #2
    Jack of all asses Wagonbacker9's Avatar
    2004 'Hoe
    Join Date
    Apr 2008
    Location
    Menomonee Falls, WI
    Posts
    26,783
    Items for Sale
    NGK zfr6f-11
    2003.5 MSP Titanium Grey #1421 - SOLD
    1994 Chevy Blazer 6.5TD - Traded
    2006 GTO Quicksilver Metallic LS2/M6 - 426hp/416tq - SOLD
    1993 Chevy K2500 - SOLD
    2004 Chevy Tahoe - Kid hauler
    1999 Chevy Camaro - Toy
  3. #3
    Spicy Speed
    03 MSP
    Join Date
    Aug 2009
    Location
    Ft. Walton Beach
    Posts
    3
    Items for Sale
    i was also thinking bout doing nology hot wires, worth it? or not
  4. #4
    2004 'Hoe
    Join Date
    Apr 2008
    Location
    Menomonee Falls, WI
    Posts
    26,783
    Items for Sale
    if your wires are old, sure, if theres nothing wrong with em, put it off til they need replacement.
  5. #5
    手前の言葉が俺は聞き捨てよう TheMAN's Avatar
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,659
    Items for Sale
    nology are a waste of money... they don't do anything
    just get a set of NGK wires and be done with it
    get the stock platinum plugs... anything lesser will just cause the plugs to wear out in 15-20k... performance will diminish fast, fuel economy suffers, and overall not good for the environment because you're throwing away plugs a lot faster than what's considered normal
    TheMAN
    '01 BJFP MT
    '05 BK3P HB AT
    For Protege and Mazda3 info, come see the Protege FAQ
  6. #6
    Banned JDM Sam's Avatar
    WARNING: This vendor is NOT an Authorized Vendor!
    Join Date
    Mar 2003
    Location
    Dallas, TX
    Posts
    4,447
    Items for Sale
    Quoted post from http://www.theturboforums.com/smf/index.php?topic=15613.msg1064039
    The iridium plugs work very well with Nitrous and with boost contrary to popular belief! Platinum though is still not suggested at least not with nitrous.
    I'd also like to clear up the misconception of what guys commonly call "copper plugs".
    There is no such thing! Copper is way too soft of a material to be in a combustion chamber and would literally melt!
    ALL of NGK's plugs and most all manufacturers that are worth a lick have COPPER CORED plugs. Standard plugs and V-power plugs have nickel alloy electrodes with a copper core. Our iridium, platinum, tungsten, gold paladium, etc all have the same copper core just a different central electrode material and or ground electrode to help with wear and or to increase performance.
    Iridium has about a 2000 degree F higher melting temp than nickel alloy and is nearly twice as strong and even has less electrical resistance. it also has a much higher oxidation point which is directly related to plug wear. These benefits are what make this material much better suited for the environment a spark plug sees. It also lets us make a tip diameter that is much smaller to aid in ignitability, reduce quenching and lowers the required voltage to fire the plug while still maintaining a life expectancy longer than a standard v-power plug. The IX series also goes a step beyond this and features a tapered ground electrode which helps reduce quenching, and allows the flame kernel to grow faster and larger, hence increasing ignitability and efficiency. This simply translates to improved torque and throttle response and an increase to fouling resistance.
    certainly this can't cover all the heads and setups that are out there. So if you have any additional questions or concerns please contact me at my desk at 248 926 6315 or you can call tech support at 877-473-6767 option 2 or shoot me a PM Hope this helps, Thanks
    Brandon Peeler
    Technical Support Representative
    Aftermarket Division
    NGK Spark Plugs (U.S.A.), INC.
    46929 Magellan Dr.
    Wixom, MI 48393
    Bpeeler@ngksparkplugs.com
    WWW.ngksparkplugs.COM
  7. #7
    Registered User lexus806's Avatar
    Join Date
    Jun 2008
    Location
    Round Rock, TX
    Posts
    715
    Items for Sale
    Quote Originally Posted by Wagonbacker9 View Post
    NGK zfr6f-11
    Get these. Close thread if u don't get em.
  8. #8
    Is it a Mazda or a Subaru KrayzieFox's Avatar
    01 MP3 Turbo
    Join Date
    Apr 2005
    Location
    Eugene, OR
    Posts
    3,320
    Items for Sale
    Quote Originally Posted by TheMAN View Post
    +1 on the Nology wires, they're a waste. Either stock platinums or ZFR6F-11 will work really well.
    If you want fancy wires, go with NGK.. but stock ones are plenty good.
  9. #9
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,659
    Items for Sale
    stock wires suck... they break easily and don't last long... NGKs are better and cost less!
    the ZFR6F-11 are normal plugs... they don't last over 15k... I ran these before and they were worn out good after 20k... normal plugs can't take high cylinder pressures and heat well!
  10. #10
    2004 'Hoe
    Join Date
    Apr 2008
    Location
    Menomonee Falls, WI
    Posts
    26,783
    Items for Sale
    they make that plug in standard (which I'm running now), platnium (which I will run next time, due to the reasoning given by theMAN), and iridium (which doesn't seem to get along with the MSP for whatever reason)...
  11. #11
    МиГ theEZV's Avatar
    2003.5 TiG MSP --> 2013 WRX
    Join Date
    Jul 2006
    Location
    Germantown, MD
    Posts
    2,607
    Items for Sale
    +1 on the zfr6f-11. no need to replace the stock wires if theres nothing wrong with them
    03.5 MSP#318 - Turbolife, SS, Greddy, ApexR1, Injen, Kartboy, Corksport, Prosport, AWR, Medieval - SOLD 12/17/12
    2013 WRX Hatch SWP - new whip
  12. #12
    Spicy Speed
    03 MSP
    Join Date
    Aug 2009
    Location
    Ft. Walton Beach
    Posts
    3
    Items for Sale
    thanks guys, i appreciate the help, ill check the wires and wont mess with em if they r fine. thanks again
Similar Threads
  1. MS6 Spark Plugs & Spark Plug Gap
    By neoshade in forum Mazda6 Engine, Transmission & Drivetrain
    Last Post: 08-22-2012, 03:53 PM
  2. Spark plugs
    By KrayzieFox in forum MSP Engine, Performance & Forced Induction
    Last Post: 12-28-2008, 03:22 PM
  3. e3 spark plugs
    By ericrapp in forum MS3 Engine, Transmission & Drivetrain
    Last Post: 01-23-2008, 07:06 PM
  4. Don't buy these spark plugs!
    By smo0f in forum MSP Engine, Performance & Forced Induction
    Last Post: 01-31-2006, 06:44 PM
  5. NGK spark plugs
    By jflo in forum MSP Engine, Performance & Forced Induction
    Last Post: 05-10-2004, 08:29 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
