Compare auto reliability with reliable results at TrueDelta.com!
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: rough idle, stalls at idle, EGR replaced 17K ago
  1. #1
    who got tha funk? Astral's Avatar
    Donated: $10
    Join Date
    Aug 2003
    Location
    Waltham, MA
    Posts
    2,815
    OK, folks, help me out.
    P5, 178K miles, recently (as of last week) developed a rough idle AND it takes longer to crank now.
    EGR replaced at 161K miles. IAC inspected at 161K miles and was clean. Spark plugs changed at 174K. Wires replaced about 110-120K.
    Today, I started it cold, it took longer than normal to crank, then it revved up to cold idle RPMs (normal), then stumbled to like 800 RPM (not normal), then back up to cold idle, and it seemed to be somewhat erratic/lopey.
    I took out the MAF and sprayed it from both sides with some MAF cleaner (also did this about 3K miles ago). Put it back in. Same behavior...
    When warm, the idle is barely maintained, it goes from 750RPM to 300-400 (almost stall), kinda cycles up and down like that until it drops low enough that it stalls.
    If I put my foot in the gas lightly, it revs up to 1500RPM and stays there, but I can tell that it's not particularly smooth.
    I can cruise the highway fine, at higher RPMs like 3K or 5K (either no load or while cruising in town), it holds them fine. Full throttle acceleration seems to be mostly there, it does not stumble on acceleration (revved it to 5.5K).
    I inspected the battery contacts, cleaned the posts, voltage stays consistent at about 14.1V, so no electrical problem there. Voltage between battery positive and the ground point on the engine is about the same.
    Blew into the PCV valve, it did let just a little air through instead of blocking it 100% in one of the ways, so I'll replace it just in case, but I doubt this would cause idle problems.
    I think the car has original coils.
    There are no check engine lights!
    Could the EGR have gone bad in only 17K miles and about half a year? Seems unlikely...
    I don't think it's the fuel pump, because it doesn't stumble on acceleration.
    Anything else I can look at?
    Should I try replacing the coils for shits and giggles? Could it be a bad MAF sensor? (But wouldn't that show up in non-idle situations as well?) Should I inspect the EGR again anyway?
    2003 Mazda Protege5, Laser Blue
    2006 Mazda MX-5 Miata GT, Winning Blue
    2005 Mazda RX-8 6-sp MT, sport package, Winning Blue (gone, but not forgotten!)
    NEPOC: Mazda Enthusiasts of New England
    National Motorists Association member: real speed limits, no speed cameras, lane courtesy (MA)
  2. #2
    Registered Zombie fishdonotbounce's Avatar
    08.5 CWP Speed3
    Join Date
    Feb 2006
    Location
    Wickliffe, OH
    Posts
    6,286
    Hmmm that's really weird. I would replace the coils just because you've tried everything else but it could be a bunch of stuff. Usually when coils go bad, you get a random cylinder misfire. Couldn't hurt to replace them though.
    Past: 2002 Turbo'd Automatic Protege5
    Current: 2008.5 CWP MS3 with a few mods - Build Thread
  3. #3
    Registered Member
    mazda protege5 turbo
    Join Date
    May 2009
    Location
    Arlington texas
    Posts
    144
    a/c on or off? Still could be the iac or egr, not likely but worth another inspection.
    BOOST ANYONE?
  4. #4
    Registered Member
    2003 Mazda Protege5
    Join Date
    Jul 2009
    Posts
    7
    Coils can get hot and go bad, a possibility since you can get it started. I take it bad sensors trip CELs...so probably not any of those. Test for coil is in 1-18 of shop manual.
    How about timing? Maybe a slipping belt? Good tension? Maybe a vacuum leak somewhere throwing off advance. Fuel pump? Bad injector?
    Just throwing some ideas out there.
    2003 Protege5 5speed odo:95k
  5. #5
    Registered Member Reitrof's Avatar
    Donated: $50
    2008 Miata PRHT
    Join Date
    Jan 2003
    Location
    Ottawa ON/Southern US
    Posts
    7,129
    Oleg, I replaced the coils twice, last about 2 years ago. Coils would be worse under load, not at idle.
    Sounds like the EGR again. Was doing the same thing when you and I replaced it.
    Bruce
    2008 Miata Touring PRHT True Red, MazdaSpeed body kit
    RB Intake, RSII Exhaust, RX8 Sways, KW V3 Coilovers, Fiaam horn
    RX7 FD Rims, Kenwood DNX7100, Int Wiper Mod, 3M Bra
  6. #6
    zoomzoom chaosProtege's Avatar
    Donated: $5.00
    03 Protege ES 5spd
    Join Date
    Dec 2004
    Location
    Richmond, VA
    Posts
    538
    thats weird, mine started doing the same thing yesterday. 45k miles on it. I'm going to try cleaning the egr see if that helps. i'll let you know.
    03 Protege ES
  7. #7
    zoom-zoom! NETC_Redd's Avatar
    2007 Volkswagen Jetta Wolfsburg
    Join Date
    Mar 2008
    Location
    Wilmington, MA
    Posts
    2,914
    sounds EXACTLY like what my car was doing when the MAF took a dive. Check that, and the engine coolant temp sensor, they both have similar symptoms.
    Just do a ohm test on them to see if they're working right.
    But yeah, I could start my car, and it would barely stay idling, once I revved it to 4k it still sounds crappy, but not as bad as the idle. Basically the car is reading too much air, and dumping fuel, which washed out the spark till it idles up again. Take out the plugs and check to see if they're covered in carbon or wet, or both.
  8. #8
    Banned
    Rust Bucket
    Join Date
    Oct 2007
    Location
    Linden/Charlotte NC
    Posts
    8,566
    u guys do know that ur not supposed to clean a MAF
    its supposed to clean itself by burning it off or if its not that type then once its dirty, its dirty
    so it may be the MAF, also check the plugs, coils maybe and vacuum leak may also be a problem
    my car did this too but then i cleaned the EGR and the throttle body cuz it was sticking
    fixed the problem
  9. #9
    Black 02 P5 Psylence's Avatar
    Donated: $10
    2002 Mazda Protege5
    Join Date
    Apr 2009
    Location
    Boise, ID
    Posts
    132
    Then what's MAF cleaner for?
  10. #10
    Donated: $10
    Join Date
    Aug 2003
    Location
    Waltham, MA
    Posts
    2,815
    Quote Originally Posted by Reitrof View Post
    OK I'll take the EGR out and see whether it's operating OK.
    Bruce, for some reason, I missed the coils in the repair log, I don't know why! I'll look again, I probably brainfarted there.
  11. #11
    Donated: $10
    Join Date
    Aug 2003
    Location
    Waltham, MA
    Posts
    2,815
    Finally got the EGR out... one of the bolts was pretty rounded, going to get replacement EGR bolts before it's back in.
    Looks like it's indeed the EGR. I didn't move easily. Spraying the shoot out of it with the carb cleaner.
    Hope that is it... wonder if the dealer will warranty the EGR valve, it's been less than 12 months and they don't have a record of my car's mileage when I bought the part (so 17K can't be easily proven). They like me there anyway, so I hope that works out.
  12. #12
    Retired MSP Racer! 122 Vega's Avatar
    03 Mazdaspeed Protege #1668,2005 Mini Cooper S, 75 Cosworth Vega
    Join Date
    Jan 2003
    Location
    Portland, Or
    Posts
    2,028
    With that many miles on your car, you'd have to think that blow by is getting worse. My EGR had to be cleaned after about 20k miles. I only have 56k on my car. Yours may tend to get gunky sooner.
    Britt
    Toyo R1R 235/40/17, TWM short Shifter/ Urethane Bushings, Indigo Pullies, Nology Wires, Oddessy P680MT Battery Wedge Seat Brackets, GT Spec Front Upper Strut Bar, Custom Swaybar Endlinks
    Coming Next:
    Pope Exhaust Manifold, Custom CAI, Custom FMIC, Corksport 80mm Exhaust, Aluminum Radiator, Mazdaspeed 6 Brakes, 17x8 Rotas, KW Variant 3 (Yes they make them)
  13. #13
    Donated: $10
    Join Date
    Aug 2003
    Location
    Waltham, MA
    Posts
    2,815
    I cleaned it and put it back in, the car is purring like a kitten. I will try to warranty the EGR anyway. I'm also gonna get new bolts. I took the old bolts and dremelled some excess rusty material on the sides to make them flat again (so that the socket would seat fully) and put them back in with antiseize.
    Thanks for everyone's help. It was indeed the EGR.
  14. #14
    08.5 CWP Speed3
    Join Date
    Feb 2006
    Location
    Wickliffe, OH
    Posts
    6,286
    Glad to know you got it all figured out.
  15. #15
    Hard as woodpecker lips Diehonda's Avatar
    Join Date
    Nov 2005
    Location
    Louisville, Ky
    Posts
    1,616
    Remove the EGR and inspect the spring and rod. You may have buildup. The coil could act up at idle or load but more under load.
    After inspecting the EGR I would run the engine and not tap the gas when it stumbles. See if it throws a code and take it in to get the code ran.
    02 P5 - sold
    07 5 - sold
    07 6 - totaled - damn deer
    10 cx7 GT - sold
    11 6 - hers
    15 6 - mine
Similar Threads
  1. CEL with rough idle, rough idle goes away when I step on gas
    By madsmartguy in forum Protege5 Lounge
    Last Post: 03-03-2009, 08:44 AM
  2. EGR Replaced & Still Rough Idle & Stumble
    By Dino1956 in forum Protege Performance
    Last Post: 02-17-2009, 08:35 AM
  3. Rough Idle
    By Sonicblue03 in forum Protege5 Lounge
    Last Post: 10-09-2008, 10:11 PM
  4. Rough Idle with AC on
    By Redcallen in forum MSP Problems
    Last Post: 09-30-2008, 05:22 PM
  5. Idle rough, stalls using AC
    By zenon in forum Protege Lounge
    Last Post: 06-22-2004, 11:50 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
