Mazda 2008 CX9 How to get to plugged drain that is causing water in passenger side
Here is a video I made to identify the bolt to remove and how to bend back the heat shield to get to the drain that you will need to blow compressed air up into. I hope this makes it easier for all of those of you with this problem.
http://www.youtube.com/my_videos_edit?ns=1&feature=vm&video_id=WPl8xXLctOI
After much taking apart... I found it. There is a little rubber hose off the bottom of the evaporator coil. The coil is located in the center console below the radio. (above the air bag module) The hose leads through the bottom of the car to the right of the gas pedal. I had to get under the car and unbolt the heat shielding above the drive shaft to get to the outlet of the drain. After getting some compressed air into the drain, all the water came rushing out, close to 1/2 gallon. I'm still drying out under the rugs on both sides. I think this has been full and leaking for a while and during my long trip is when it got really full and noticalble.
