blacksheepms3
- Mazdaspeed 3
If you managed to get your AP stuck on "updating" screen while updating your firmware this is what you should do...
"Try connecting your AccessPORT to the AccessPORT Manager software. If it is able to connect an AccessPORT icon will pop into the Sources column on the left hand side. You can then click on the View -> Advanced option and that will pop up an empty window. Close down that window and close down AccessPORT Manager. That should kick the AccessPORT back to the main menu and allow you to re-run the update if needed or it is possible the update finished and the AccessPORT just needed to restart. Let me know if this works. "
Tech support given by Chris Haag from Cobb
