In Memory of Mazdas247 Member "1338"
Results 1 to 5 of 5
Thread: MPV 2001 starter problem
  1. #1
    Registered Member
    Join Date
    May 2009
    Posts
    1
    Hello,
    I have a 2001 MPV ES. The van was having problems starting and my mechanic said it was a bad starter. He replaced the starter with a rebuilt model, but that also started funny. He replaced the starter 2 more times and they all started weird. Next week, he will attempt to replace it a 4th time. Yesterday, I had the battery, starter and alternator checked at Sears. They said the battery was bad and they gave me a brand new battery (under warranty) and said the starter and alternator were fine. The problem is that the the van still starts weird sometimes. It makes that nasty sound that you hear if you attempt to start an engine that is already started. Someone suggested that it could be a bad flywheel. Can anybody give me any suggestions as to what the problem could be or direct me to a website that can help. Any help would be appreciated.
  2. #2
    Registered Member
    Join Date
    Jul 2009
    Posts
    1
    Hi,
    I'm having exactly the same problem with my mpv 2001. I already had the starter replaced and it continues to happen sporadically. My mechanic said it could be a number of problems such as the ignition switch, solenoid, computer issues. He cannot fix it unless he heards it. He had it in the shop all day and he couldn't replicate the problem. Of course it only happens when its out of the shop.
    He doesn't advise changing everything because it is hit and miss.
    Did you find a solution to your problem yet.
    Would appreciate your help.
  3. #3
    手前の言葉が俺は聞き捨てよう TheMAN's Avatar
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,577
    it could be a bad starter solenoid, but bad battery cables or terminals can cause this too
    remember this:
    BAD/WEAK BATTERIES KILLS STARTERS AND ALTERNATORS!!!
    TheMAN
    '01 BJFP MT
    '05 BK3P HB AT
    For Protege and Mazda3 info, come see the Protege FAQ
  4. #4
    Registered Member
    Mazda Millenia S
    Join Date
    Nov 2008
    Location
    Miami
    Posts
    43
    It cant be the starter solenoid if the whole starter itself has been replaced several times. I would check the condition of the teeth on the flexplate. Then check for voltage drop between the battery and where the wires connect to the starter to make sure its getting good power and ground.
  5. #5
    Join Date
    Oct 2002
    Location
    Dallas, TX
    Posts
    5,577
    but it CAN be
    I've seen all sorts of problems with brand new reman whatever bullshit from vatozone
    try ordering a denso starter online... it'll cost more but you will NOT regret it!
Similar Threads
  1. Remote Starter Problem
    By rotorbaru in forum Mazda5 Audio
    Last Post: 08-28-2008, 01:04 AM
  2. 2002 ES Starter Problem?
    By NauPruz in forum Protege Performance
    Last Post: 01-29-2008, 10:38 PM
  3. Problem with OEM alarm/remote starter!
    By rx7_drifter_ in forum Mazda Tech & How-To
    Last Post: 05-03-2007, 09:20 AM
  4. possible starter problem?
    By MSP608 in forum MSP Performance
    Last Post: 06-18-2006, 10:31 PM
  5. Remote Starter possible problem?
    By WalksInDarkness in forum Mazda3 Lounge
    Last Post: 07-26-2005, 12:44 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
