Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 4 of 4
Thread: whistling sound underneath my brake pedal on my mazda 05 tribute
  1. #1
    Registered Member
    Join Date
    May 2009
    Posts
    1
    Whenever I press the brake down on my mazda tribute there is a whistling sound that I hear underneath the brake pedal what causes this?
  2. #2
    I Save Lives Biotch!! zuku26's Avatar
    spicy MSP
    Join Date
    Sep 2007
    Location
    Chicago
    Posts
    3,547
    Your in the wrong forum Mr. Ballard
    Here's the area you might have some better luck on:
    http://www.mazdas247.com/forum/forumdisplay.php?f=14
    I'm sure a MOD will end up moving this thread there anyway
    MAZDATEAM MEMBER= ZUKU26
    Clocked GT28RS, Split Second, YellowSpeed Coilovers, P.E.P 3" 304SS downpipe, Forge WGA, Perrin 3" catless exhaust w/ Corksport Polyurethane hangers, AWR MM, MAM Hard Pipes, SSQV, CXRacing FMIC, Corksport aluminum radiator, SPAL Slimline Fans, Magnum Cross drilled, Hawk HPS pads, Dunlop Direzza tires, ForceFeds Dual gauge Bezel and steering column pod, Dexter hood prop, Custom Vac Block
    Quote Originally Posted by JDM Sam View Post
    I'm one of those people who see modding as a paint canvas not an investment. It's not a hobby, it's a way of life and passion.
  3. #3
    Wham Bam thank you Ma'am Velocifero's Avatar
    Georgia & GACC Moderator
    VRM MS6, Sunlight Silver MSP
    Join Date
    Nov 2004
    Location
    Atlanta, Ga
    Posts
    6,975
    I am not going to jump on your case but this is the wrong forum section for this question. This is the Mazdaspeed Protege threads. I am sure the moderator will move it shortly to the proper area, no harm done.
    Can you describe the sound a little more. Is it a screeching grinding sound or simply put, a whislte sound? Any chance you can get a video with the noise or perhaps a sound byte? Can it be heard outside the truck or literally it is coming from beneath the pedal? What year and engine size, 4 or 6, manual or auto?
    You like the Harlem Shake? See mine..
    http://www.youtube.com/watch?v=J2o13...P8UN4OMXCys86g
  4. #4
    Is it a Mazda or a Subaru KrayzieFox's Avatar
    01 MP3 Turbo
    Join Date
    Apr 2005
    Location
    Eugene, OR
    Posts
    3,573
    Im gonna state the obvious.. but have you checked the brake pads? Sound deflects very easily and its often hard to pinpoint the exact source from inside the cabin. It could just be the pads are worn and you're hearing the wear indicator pin rubbing on the rotors..
Similar Threads
  1. Brake light doesn't flash when brake pedal pressed
    By goodfornothing in forum Protege5 Lounge
    Last Post: 11-05-2008, 09:39 PM
  2. 1st gear sound engaged while clutch pedal depressed.
    By blacksheepms3 in forum MS3 Engine & Transmission
    Last Post: 12-19-2007, 10:54 PM
  3. clicking sound underneath the chasis.
    Last Post: 08-17-2007, 03:51 PM
  4. Whistling sound when driving faster than 90 or so
    By fattyboombatty in forum MSP Lounge
    Last Post: 08-28-2005, 12:52 PM
  5. Whistling Sound
    By Gizmo360 in forum Mazda Tech & How-To
    Last Post: 04-19-2004, 01:44 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
