Visit TeamMFactory.com for the best Mazda transmission components!
Results 1 to 3 of 3
Thread: hard to start / long crank
  1. #1
    Registered Member
    Join Date
    Aug 2005
    Posts
    162
    Hey everybody.
    Our P5 lately has been hard to start - taking longer to fire up. Battery is fine, the starter spins normally, but the motor just takes more cranks before firing. Seems to be progressively getting worse.
    I checked the service manual and there is an 18 point flow chart to follow...
    But before I just start down that path...
    Maybe there is some collective wisdom that will help me pin this down.
    Car has 110K miles.
    plugs and air cleaner have 22K, so I doubt they are the culprit.
    Here is the list of items:
    POSSIBLE
    CAUSE
    Spark leakage from high-tension leads
    • Vacuum leakage
    • Poor fuel quality
    • Starting system malfunction - (does not seem like it)
    • Spark plug malfunction - (doubt it)
    • Air leakage from intake-air system
    • Erratic signal from CKP sensor
    • Erratic signal from CMP sensor
    • Air cleaner restriction - (doubt it)
    • IAC valve malfunction
    • PCV valve malfunction
    • Inadequate fuel pressure
    • Purge solenoid valve malfunction
    • MAF sensor contamination
    • Restriction in exhaust system - (doubt it)
    • EGR valve malfunction
    • Pressure regulator control (PRC) system malfunction
    Any of those items more likely than the rest given age and miles?
    Car is 5.5 years old, 110K miles.
    These cars do not seem to have fuel filters - right?
    Built into the tank?
    that is what my parts guy told me.
  2. #2
    Riddle me that! slavrenz's Avatar
    2001 Mazda Protege LX 2.0
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    Yes, the fuel filter is built into the tank. You can check your fuel system, but it is sorta difficult and best left to a pro IMHO.
    Easy things - if you haven't, replace your ignition coils. They are notorious for going bad on our cars, and at 110k miles, you're on borrowed time. Also, check your intake boot to make sure it is not ripped in the accordion-style part of it. These also seem to go bad quite frequently on our cars, and will result in a large vacuum leak.
    Otherwise, clean your EGR valve (search for the How-To on this forum), and see if anything is improved after all this.
  3. #3
    Registered Member
    Join Date
    Aug 2005
    Posts
    162
    Quote Originally Posted by slavrenz View Post
    I was thinking EGR valve too - might be something to try first.
    There is no CEL btw. The intake did rip and I repaired it because a replacement from mazda was expensive. I used this thick heat shield material which worked perfectly. That happened at least a year ago, so I should double check to make sure it is all still in place.
    I will do those and look for other vacuum leaks before considering coils.
    The coils are about $80 each, so it is a $350 job, plus probably wires so talking $400. Do these regularly start to fail at this mileage? Seems odd.
    I should also clean the IAC valve and replace the PVC before doing anything else.
    The troubleshooting list from the manual does not even list the coils, which is interesting. First thing I thought of was ignition, weak spark, etc.
Similar Threads
  1. 626 will crank, but not start
    By jalbao in forum Other Lounge
    Last Post: 04-27-2008, 10:57 PM
  2. P0442 CEL, hard start
    By Bombard in forum Mazda6 Engine & Transmission
    Last Post: 02-10-2007, 05:37 PM
  3. hard cold start
    By bazooka joe in forum Mazda Tech & How-To
    Last Post: 07-25-2006, 01:56 PM
  4. Hard Start in Cold Weather
    By markus3 in forum MS3 Engine & Transmission
    Last Post: 01-25-2006, 09:16 AM
  5. How long before the MSP becomes hard to find?
    By Jhova1012 in forum MSP Archives
    Last Post: 09-10-2003, 11:38 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
