Compare auto reliability with reliable results at TrueDelta.com!
Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: Manual transmission, shifting!
  1. #31
    Registered Member
    Join Date
    Oct 2008
    Posts
    6
    1-3-5
    Maybe it's because I'm an old fogie. I shift 1-3-5, and cruise at 60kmh(in the city). I found that's saves the most gas. I did an experiment, one tank fast acceleration to legal speed limit, lots of passing on the highway etc. Then one tank with 1-3-5(no bogging), and steady cruising on the highway. I got about 30% better fuel economy. I still open her open once in a while, I'm not that old
  2. #32
    Jack of all asses Wagonbacker9's Avatar
    2004 'Hoe
    Join Date
    Apr 2008
    Location
    Menomonee Falls, WI
    Posts
    26,747
    passing usually involves a lot accelerating and decelerating.. thats exactly what I would expect. I skip gears sometimes getting onto freeways, but its usually because I had fun winding one gear out and don't need to accelerate anymore. lol
    2003.5 MSP Titanium Grey #1421 - SOLD
    1994 Chevy Blazer 6.5TD - Traded
    2006 GTO Quicksilver Metallic LS2/M6 - 426hp/416tq - SOLD
    1993 Chevy K2500 - SOLD
    2004 Chevy Tahoe - Kid hauler
    1999 Chevy Camaro - Traded
    2001 Lincoln LS - WHAT A PIECE OF $#!& - SOLD
    2008 Pontiac G8 GT - White Hot
  3. #33
    Mystery Flavor
    2003 Protege5
    Join Date
    Aug 2008
    Location
    Milwaukee
    Posts
    288
    Quote Originally Posted by Wagonbacker9 View Post
    1-2-5 FTW
  4. #34
    The one and only magnumP5's Avatar
    1986 RX-7
    Join Date
    Sep 2005
    Location
    Richmond, VA
    Posts
    8,530
    Items For Sale
    My 1-2 shift is usually between 3500-4000 RPM and all others are 3000-3500 RPM for regular driving. Also, I will never cruise along in this car below 2500 RPM unless I have to (second gear in a parking lot, for example). I truly believe these cars are most efficient between 2500-3000 RPM so puttering around below or staying up high aren't helping you at all. If you're cruising too low you will either have to mash the gas more or downshift to accelerate - both burning more fuel. Also, if you're zooming down the road at 5000 RPM you're just burning off fuel. Remember, above a certain RPM the ECU automatically throws the car in open loop despite engine load and will start dumping fuel. I've said this many times before but I really wish I had an engine map for the FSDE - they're so easy to find for just about any diesel engine so why not gasoline? FWIW, mpg is not a true measure of an engine's efficiency - what you would need to do would measure the fuel consumption mass per unit time per unit power (specific fuel consumption). In the aviation industry we measure engine efficiency in lb fuel (mass) per hour (time) per lb thrust (force).
    '13 Ford Flex Limited w/ Ecoboost - DD
    '10 Volkswagen Jetta TDI - Wife's
    '86 Mazda RX-7 Base - Project
    '11 Mazda 2 Touring (DD) - SOLD
    '09 Toyota Tacoma SR5 4x4 (Hauler) - SOLD
    '02 Mazda Protege5 - (Turbocharged, 215 whp, 220 wtq) - SOLD
    '01 Mazda Protege LX 1.6L (Wife's) - SOLD
    '89 Mazda RX-7 GXL (Project) - SOLD (many parts left)
    '86 Toyota Pickup 2WD (DD/Hauler) - SOLD
  5. #35
    2004 'Hoe
    Join Date
    Apr 2008
    Location
    Menomonee Falls, WI
    Posts
    26,747
    thats basically fuel consumption/hp.... thats literal efficiency. Most people don't care so much about that because MPG is the number you can translate to what comes out of your pocket...
  6. #36
    1986 RX-7
    Join Date
    Sep 2005
    Location
    Richmond, VA
    Posts
    8,530
    Items For Sale
    It is, but I just get sick of people going on about how efficient some car's engine is just because it gets good fuel economy. Show me a car that can do 40 mpg while making 300 hp and I'll be impressed...
  7. #37
    2004 'Hoe
    Join Date
    Apr 2008
    Location
    Menomonee Falls, WI
    Posts
    26,747
    well, a turbo is basically designed to assist in just that... its power on demand... fuel efficiency when you want that, and the ability to make big power when you want that instead. The real limit is engineering, and the simple fact that burning of fossil fuels isn't very efficient to begin with...
  8. #38
    Registered Member
    2002 Mazda Protege 5
    Join Date
    Mar 2009
    Location
    Howell, NJ
    Posts
    811
    Quote Originally Posted by br289165 View Post
    Snatch gears?
    Shifting without the clutch
  9. #39
    Mystery Flavor
    2003 Protege5
    Join Date
    Aug 2008
    Location
    Milwaukee
    Posts
    288
    i find myself granny shifting on a regul4r b4s15.
  10. #40
    2004 'Hoe
    Join Date
    Apr 2008
    Location
    Menomonee Falls, WI
    Posts
    26,747
    Quote Originally Posted by BlackCherry View Post
    I would think it'd be a lil rough on the syncros... but I know a tow truck driver that had like 250K+ on his rig, and he did it.
  11. #41
    low pro Sliver5's Avatar
    2002 Protege 5
    Join Date
    Apr 2007
    Location
    Richmond
    Posts
    2,403
    pedal to the metal all the time.
    even when I'm hitting the brakes.
Similar Threads
  1. Replies: 15
    Last Post: 08-06-2015, 03:36 AM
  2. 1.6l automatic transmission swap to a manual transmission
    By Protege-Fiend in forum Protege Performance
    Last Post: 06-22-2010, 07:00 PM
  3. Transmission shifting oddly
    By altaski in forum CX-7 Lounge
    Last Post: 07-08-2008, 10:01 PM
  4. Manual Transmission
    By danguyon in forum Protege5 Lounge
    Last Post: 01-26-2008, 12:00 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
