Transmission fluid change
I just talked to the guy at Maxi and he wanted to know if the pan to drain the tranny fluid was on the bottom or the side... apparently if it's on the bottom and easier to get to and thereby cheaper.
Is the pan on the bottom?
What type of transmission do you have?
If Its a manual, you drain on the bottom and you fill on the side.
Auto you drain from the bottom. Remove the bottom pan to replace the filter/strainer (auto only).
Latest posts
