Cup Holder console
E
ericw
Ok guys and gals.. tell me.
I have the 2002 Protege 5 and like the console / cupholder better in the 03.5. Will this fit in mine?
It will fit, but there will be a little bit of a lip on the side facing the centre console. They hold drinks much better then the bad flip-up ones though!
You'll have to replace the entire center console if you want everything to line up properly. The later model center consoles came up higher where the cupholders are. If you just swapped the tops there would be gaps on either side.
I swapped mine for a flip up and it looks fine. It does dip down, but there are no gaps...
