Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 4 of 4
Thread: remove rear bumper
  1. #1
    2010 speed3 kachur779's Avatar
    2010 speed 3 black
    Join Date
    Mar 2008
    Location
    vancouver
    Posts
    116
    remove rear bumper
    ive never removed the rear bumper off a car before only the front to install my fmic could some one help me out here so i have an idea what to do before i start ripping out stuff that i dont need to i have water leeking in my trunk on both sides like where the jack goes and the other side so i need to take the bumper off and see where the water is leeking in fun!!
  2. #2
    Registered Member bruster4_5's Avatar
    mazdaspeed protege'
    Join Date
    Mar 2007
    Location
    Danville VA
    Posts
    336
    ull need a torx bit I think its a T30 an 8 mm, a 10 mm socket and ratchet, and something to remove clips with. a small flat head scre driver will work.....there are 2 8mm screws on each side of the front corners. one on each side below on the bottom of the bumber...2 torx screws where the trunk meets the bumber and ull need to remove the tail lights to get to the clips that are under them there are 3 10mm holing each light in.....hope that helps
    10.12@69mph 1/8 mile
    MODS...Vibrant exhaust, Injen CAI,Greddy RS BOV, Altered Customs FMIC kit, Hallman Boost Controller, ATP Wastegate Actuator, Mfactory LSD, Exedy Stage 1 Clutch, Fidanza Flywheel, Dave B rings Autometer 3 gauge pillar pod, Autometer vac/boost gauge, Autometer oil temp and pressure gauge, custom painted strut bar, painted calipers, painted interior pieces, black sued headliner, sun visors and pillars, 35% window tint, Boston G1 10" sub, JDM fiberglass grille and AWR front and rear motor mount, Weapon R billet coolant tank, tinted taillights, Corksport exhaust hangers, Eibach Sportline lowering springs, BFGoodrich KDW 215/45/17
    SOON TO INSTALL
    Steedspeed Exhaust, Altered Customs Air Diversion Panel
  3. #3
    FREAKY, BUT I LIKE IT!!!! mp3-79bronco's Avatar
    2001 protege mp3
    Join Date
    Dec 2007
    Location
    Howe, Texas
    Posts
    1,945
    its coming from behind the tails, theres a how to in the how to section on fixing it
  4. #4
    2010 speed 3 black
    Join Date
    Mar 2008
    Location
    vancouver
    Posts
    116
    right on thanx ill take a look at the how to ,but the car took a small hit in the back so i think it must of caused a leak some where on both sides
Similar Threads
  1. How to remove rear bumper HELP
    By fictionbaby in forum Protege Appearance
    Last Post: 04-29-2008, 05:50 PM
  2. How hard is it to remove the rear bumper of the RX8?
    By Matthew in forum Rotary Lounge
    Last Post: 05-05-2007, 11:59 AM
  3. How do I remove the rear bumper?
    By Nutari in forum Protege5 Lounge
    Last Post: 07-07-2005, 05:24 AM
  4. remove rear bumper guard?
    By bigj884 in forum Protege5 Lounge
    Last Post: 04-23-2005, 07:33 PM
  5. How do I remove dent in rear bumper?
    By Siva in forum MS3 Lounge
    Last Post: 04-22-2005, 06:51 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
