Get +66HP & +27TQ from your 2nd gen MAZDASPEED3 w/ Hypertech!
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Headlight adjustment
  1. #1
    Where are the heck the adjustment screws for 2002 Protege5's headlights? My headlights need to be adusted so badly, but I can not find any adjustment screws around the headlights like my 1980Chevy pickup does. My lowbeam is aiming perfectly horizontal and my high beam is aiming above the horizontal line. I have to aim them much lower.
    Thank you in advance for your help.
  2. #2
    Registered User o.g.sk8er's Avatar
    Join Date
    Jul 2002
    Location
    los angeles, ca
    Posts
    1,506
    Items for Sale
    Stanced Member No. 5
  3. #3
    Thank you, o.g.sk8er. I am going to try to find it and make an adjustment.
  4. #4
    ......................... i12drivemyMP5's Avatar
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    <-----hou,tx----->
    Posts
    6,223
    Items for Sale
    There aren't seperate adjustments for low & hi. Set the lows, deal with the highs or the opposite if you happen to use highs more than lows.
  5. #5
    Team Fail Motorsports mx-p5's Avatar
    Donated: $5
    03.5 Protege5
    Join Date
    Dec 2006
    Location
    North of South FL, yet still South of Central FL
    Posts
    10,730
    Items for Sale
    Please properly aim the lows.
    If they are aimed right, the high's are just right as well
    If that isn't neough, you can always upgrade the foglights to a driving light
    Wife's Protege5
    Protege to MX-5 lineage
    Kevin did it before Phil did, Phil was before Andrew, who was before Bruce, Chris, Tony, Phen, Tylor, Mahk, Roy, John, Jerry, Rob, Shadow, Josh, Scratch, Dub, Andrew, Vocko, Matt V, Protojason, chiefmg, Tungsten, 2.0t03speed and Tylor again
  6. #6
    Registered User
    02 Midnight Blue MP5
    Join Date
    Dec 2008
    Location
    Kingston, ON
    Posts
    73
    Items for Sale
    At night take the car to a dark parking lot or alleyway where there is flat level ground beside a building or wall, park the driver side of the car close to the wall in a paralell manner. You should see the beam of the headlights and a decent cutoff line to work with. Now block off the pass light with a towel or something so that its beam does not hit the wall this will allow you to adjust the drivers side, from the headlight to about 25' ahead the beam cutoff should drop no less than 2", that from what I can remember is the proper DOT limit. Next do the passenger light by again covering up the drivers side light.
    Reason for using the drivers side of the car for light aiming is that the right side of the beam will deflect up diagonally which makes aiming very hard.
  7. #7
    Donated: $5
    323F
    Join Date
    Apr 2005
    Location
    <-----hou,tx----->
    Posts
    6,223
    Items for Sale
    Quote Originally Posted by Guvner View Post
    Might wanna park perpendicular to the wall so the lights will shine on the wall. Then just drive around & see if they hit where you want them too. If not stop & adj again. It's all about what they're shining on when driving so you can't just adj on the wall, gotta see where it's hittin when driving.
  8. #8
    Donated: $5
    03.5 Protege5
    Join Date
    Dec 2006
    Location
    Posts
    10,730
    Items for Sale
    I just adjust till they are too low, then continue to drive around bringing them up till i get flashed
    then, take em back down 1/8 to 1/4 turn, then i'm golden
  9. #9
    Registered User
    Join Date
    Dec 2008
    Location
    Kingston, ON
    Posts
    73
    Items for Sale
    Quote Originally Posted by i12drivemyMP5 View Post
    but if they are lined up but pointing up blinding other drivers you won't be able to tell by pointing the car at a wall. Parking parallel to the wall, very close to the wall that is you can see your beam along the wall and see the slope of the beam.
    Pic of my old MP3 with HID projectors. This is what I mean
  10. #10
    Donated: $5
    03.5 Protege5
    Join Date
    Dec 2006
    Location
    Posts
    10,730
    Items for Sale
    What happened to those headlights?
    What projectors were they?
  11. #11
    Registered User
    Join Date
    Dec 2008
    Location
    Kingston, ON
    Posts
    73
    Items for Sale
    That car and its lights are long gone, they were Audi RS4/RS6 bi-xenon's.
  12. #12
    Donated: $5
    03.5 Protege5
    Join Date
    Dec 2006
    Location
    Posts
    10,730
    Items for Sale
    Can I ask why?
    I've got Acura TL's being retro'd into sedan lights.
  13. #13
    Registered User
    Join Date
    Dec 2008
    Location
    Kingston, ON
    Posts
    73
    Items for Sale
    I sold the lights to some other MP3 owner a couple months before I sold the car which was back in early 2007. Loved the lights and would love to have the cash to do a retro in my new MP5, but I'm broke.
  14. #14
    Registered User
    2003 Mazda Protege 5 manual
    Join Date
    Dec 2012
    Location
    Chicago
    Posts
    7
    Items for Sale
    Quote Originally Posted by o.g.sk8er View Post
    Is this a typical phillips head screw? Also, what direction does the headlight move then the screw goes clockwise (when imagining that I'm looking directly at the screw head from inside the car)?
    I need to adjust mine a bit as well but don't want to screw anything up.
    -Ivan
  15. #15
    TEAM PRO 5 VICE PRES. 808MP5's Avatar
    Donated: $8.08
    Team Pro5 Moderator
    GT3076R Pro5
    Join Date
    Jul 2007
    Location
    Zip Code 96744
    Posts
    3,962
    Items for Sale
    righty tighty (down)
    lefty loosey (up)
    there's also another bolt towards the outside of the back housing that makes the lights go left and right
    don't force it... if at any point it stops moving stop turning... you will strip the cheapo plastic thing those bolts screw into... you will have to open the lights to replace them
    i've learned from experience... but if you do strip them... i've found similiar pieces at o'reallys that i replaced mine with
Similar Threads
  1. Headlight Adjustment
    By PWR SHFT in forum Mazda3 & MAZDASPEED3 Car Audio & Electronics
    Last Post: 11-18-2005, 11:01 AM
  2. Headlight Adjustment
    By Grey Ghost in forum Mazda3 & MAZDASPEED3 How-To
    Last Post: 11-14-2004, 10:08 PM
  3. headlight adjustment?
    By vividmaz3 in forum MAZDASPEED3 Forum
    Last Post: 04-27-2004, 07:11 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
