Your Best Source for Genuine Mazda Parts!
Results 1 to 3 of 3
Thread: How to: Remove front bumper
  1. #1
    Registered Member davens's Avatar
    Join Date
    Mar 2004
    Location
    Kyle, Texas
    Posts
    161
    (I found this on torontomazda3.ca, so all credit due)
    http://torontomazda3.ca/forum/showthread.php?p=360413
    I was looking for a good spot to mount HID ballasts, so I removed the bumper. I was able to mount them directly under each headlight. So, if you need to remove your bumper for whatever reason...HID install, CAI install, whatever....these directions made it extremely easy.
    1. Remove the 11 8mm (or phillips) screws on the bottom of the bumper.
    2. Remove the two big phillips screws by the hood latch
    3. Remove the two big plastic with rubber bumpers (use a small flat head to pop up the collar, then pull the entire thing out)
    4. Take off the two plastic phillips clips holding the mud shield back in the wheel well towards the front. (per side)
    5. Pull back the shield alittle and you'll see another 8mm screw by the bumper seam, take it off. (per side)
    6. Bumper is now free but still hanging in place. By the hood latch will be two big hooks that clip onto the sub frame. After you slightly pull these up the bumper is now in your hands.
    7. Remove the wiring for fog lights if applicable. And all other wiring. Set bumper aside.
    08 S Sport
    02 LX...sold!
    98 DX...sold!
  2. #2
    Asian Persuasion <>< Hank3's Avatar
    Contributor
    '03 Protege5 & '10 Mazda5 GT
    Join Date
    Oct 2002
    Location
    Tallahassee, FL
    Posts
    4,358
    You should add a step in the how-to about pulling the bumper to the sides to unsnap it from the retaining clips. And since this is the Speed3 part of the forums, you'll need to undo the two air ducts leading to the I/C. I forget, but they're either fastened by pastic clips or bolts.
  3. #3
    Join Date
    Mar 2004
    Location
    Kyle, Texas
    Posts
    161
    Actually, I posted this in the plain old Mazda 3 section...it appears to go to the same place. So, you should feel free to elaborate on any MS3 specific steps that would be applicable.
Similar Threads
  1. Please help me remove my front bumper.
    By ravi189 in forum Protege5 Lounge
    Last Post: 11-23-2008, 10:29 PM
  2. how to remove front bumper
    By MP5_85 in forum Protege5 Lounge
    Last Post: 08-20-2008, 09:32 AM
  3. How to remove front bumper?
    By Karma_hunden in forum Mazda3 Lounge
    Last Post: 04-07-2006, 08:10 PM
  4. How do I remove the rear bumper?
    By Nutari in forum Protege5 Lounge
    Last Post: 07-07-2005, 06:24 AM
  5. NEED HELP, how to remove front bumper
    By BJA in forum Protege5 Lounge
    Last Post: 02-28-2002, 06:23 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
