Your Best Source for Genuine Mazda Parts!
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: Bad Wheel Bearing?
  1. #1
    Registered Member AznXstazy's Avatar
    Mazda MP3
    Join Date
    Aug 2004
    Location
    Richmond, VA
    Posts
    1,481
    Bad Wheel Bearing?
    hey guys, wondering what kind of symptoms would a bad wheel bearing cause? right now i get this REALLY bad thumping from the passenger side front. my dad said it could be the wheel bearing and i think it could be too just cause i replaced the axle over there and might have over tightened the bolt. got the wheels balanced already. the noise went lower, but still there. getting worst as i drive it more. any ideas?
  2. #2
    Now I zoom zoom x 2 zoomin MP3's Avatar
    Donated: $5
    Blue MP3/06 MPV
    Join Date
    Mar 2005
    Location
    Colorado Springs, CO
    Posts
    664
    Questions you have like this that aren't MP3 specific, you might want to type in the general protege area, just to get more responses. But does it constantly thump? Is it a heavy sound (thick metal) or more of a tinny sound? Does it grind, or more of just two pieces hitting together? Does it do it more while turning, if so, does it do it more to one side than the other?
    Installed: EVO style CF hood and decklid, Buddy Club 2 sideskirts and rear bumper, DG front lip, iSport CF ADP, Daveb brushed gauge rings, AWR front motor mount, SLS Pass mount, medieval LW pullies, K&N CAI with custom ram air tube, TWM ss w/ weighted knob, Mazda Racing 4-2-1 header, Magnaflow custom exhaust, NGK long reach plugs, AXR "clunk fix" bracket, HID conversion, "Dual" headunit, MP3 seatbelt pads, smoked fender lights, painted/smoked tails, yellow calipers, ground wire kit, Braille 15 lb battery, Redlinegoods shift/e-brake boots, slotted/drilled rotors
    #683 (bluemp3) Need some upgrades for your pro? Be sure to check out my FOR SALE page.
  3. #3
    Mazda MP3
    Join Date
    Aug 2004
    Location
    Richmond, VA
    Posts
    1,481
    ya ill try posting in there later. the noise happens when going straight, but if i go in a right turn at a certain point of the turn there will be no noise, but as soon as i go back straight or turn to much right then the noise comes back. and yes constant thumping. not metal sounds like wheel need balance bad, but it doesn't. already got all 4 done and rotated. don't hear any grinding. can't tell if its coming from passenger or driver, but i think i hear more from passenger side.
  4. #4
    Registered Member Tzar177's Avatar
    Donated: $15
    Join Date
    Jul 2005
    Location
    Northern Kentucky
    Posts
    2,803
    could be the cv joint
  5. #5
    Registered Member ggrab's Avatar
    2002 Protege5 & 2001 MP3
    Join Date
    Dec 2008
    Location
    Sylvania, GA
    Posts
    17
    As a general rule a bad bearing do not cause thumping type noises. A bad bearing usually exhibits a grinding or squealing type noise. Thumping noises could be a unbalanced wheel (as you already suspected) an out-of-round wheel/tire, or possibly a bad CV joint. Strange noises that come from the front and change dramatically with turning of the steering wheel often indicate problems with the CV joint.
  6. #6
    Canadian eh? CulRidr's Avatar
    Donated: $10
    Laser Blue MP3
    Join Date
    Jan 2006
    Location
    Ottawa (ON), Canada
    Posts
    2,345
    ^turning of the steering wheel can also either accentuate or attenuate noise generated by a bad wheel bearing
    MY BUILD!
    Go
    Engine:Custom 421 header&Magnaflow midpipe,RB catback w/CS&Kartboy hangers,K&N CCAI,Medieval pulleys&MMs,NSN spacers,Twiggys,SpeedCircuit stage2,FSZE pistons,Fidanza flywheel,adj.cam gears,AWR pan
    Suspension:Bspec&Aspec,AXR,GTspec links/cage, Autoexe tie bar,RacingLine endlinks
    Wheels & Brakes:Yoko AD07,MSP front brakes,KVR lines,HPS pads,Kosei K1s w/RE01R(autox)
    Transmission:welded MSP LSD,TWM SS w/bushings,CS clutch line,626 5th gear
    Show
    Exterior: painted rims & emblems,Mintblue grill,smoked clear sidemarkers,foglight deletes,LED&chrome bulbs, painted calipers,Tribute nozzles
    Interior:NGK AFX,Prosport gauges,daveBs,MS sidesills/mats/centre console,SD Boots,LED lighting
    Engine:Optima,painted/cut valve cover,hood props,ADP,grounding kit,Gujustud
    Audio:Sirius
    Not yet on the car
    Xpel headlight covers,XC eyelids,MZ3 mirror,secret project,Kenwood upgrade
    OttawaMazda
  7. #7
    Registered Member MP3Performance's Avatar
    Mazda MP3
    Join Date
    May 2006
    Location
    IL
    Posts
    484
    Sounds like the same exact thing that happened to me a couple months ago. I had the same symptoms but at first I didn't think it was a bearing since there was no metal grinding sound and there was no "wiggle" when you yanked on the wheel. After a couple days finally went to a mechanic friend and he replaced the passengers side bearing and the noise went away. If the sound goes away when you turn right that means most likely your passenger side front bearing is going/has gone bad.
  8. #8
    Donated: $5
    Blue MP3/06 MPV
    Join Date
    Mar 2005
    Location
    Posts
    664
    I'd check the CV joint first. That usually doesn't make a noise going straight, just when you turn. And it's louder/worse on the side you're turning to (turning right, it'll be worse and it's the right CV). Doesn't really sound like a wheel bearing, but like MP3performance said, same thing happend to him.
    Done any work on the brakes lately? My roommate in college had a bad experience where the top caliper bolt was either forgotten, or not tightened. The caliper "leaned" away from the rotor and was rubbing the rim. It had a "thump" noise to it. This is the WAY extreme end of possibilities, but it's more stuff to rule out.
  9. #9
    TEAM PRO 5 VICE PRES. 808MP5's Avatar
    Donated: $8.08
    GT3076R Pro5
    Join Date
    Jul 2007
    Location
    Zip Code 96744
    Posts
    4,056
    subbed
  10. #10
    Mazda MP3
    Join Date
    May 2006
    Location
    IL
    Posts
    484
    Quote Originally Posted by mgs_freak View Post
    Defiantly check around the cv axle before you do anything. In my situation I ended up taking apart both cv axles, both sides of brakes, and even the bearing on the axle right behind the engine. All this because I was convinced this sound could not be coming from a wheel bearing.
  11. #11
    Mazda MP3
    Join Date
    Aug 2004
    Location
    Richmond, VA
    Posts
    1,481
    ya im not sure. i was searching and a prelude had the same problem as i was describing and it was his bearing. i thought it was my axles too, but i looked no rips nothing loose. i will keep you guys updated on what it is. gonna start taking stuff apart before school next week.
  12. #12
    Mazda MP3
    Join Date
    Aug 2004
    Location
    Richmond, VA
    Posts
    1,481
    k guys, weathers been crappy and i dont have a garage so work on the car is slow. but i wanted to get others opinions before i start taking stuff apart.
    so to sum things up
    - i make a left turn noise gets louder and more faster
    - i make a right turn at a certain spot where i don't to to much right and not going straight the car will NOT make the noise.
    so you guys think its the passenger side bearing? i never messed with that side. i did change the knuckle on the driver side. so maybe its the driver bearing? but the noise and passengers say they can feel it a lot on the passenger side.
    what do you guys think?
  13. #13
    Mazda MP3
    Join Date
    May 2006
    Location
    IL
    Posts
    484
    it is your passenger side wheel from what you say. the reason is when you turn left the right tire (passenger side) becomes the outside tire on the turn, meaning the load of the car is transferred more onto that wheel. Since there is more load on the wheel the bearing is being "squished" and thus amplifying the sound. the second point you posted also happened to me when I had the bearing problem, it wouldn't make any noise if I held it perfectly straight or a tiny bit to the right.
    I think we need someone else to chime in since I don't want it to turn out that I have been saying all this stuff about bearings and such and in the end it is something else
  14. #14
    Mazda MP3
    Join Date
    Aug 2004
    Location
    Richmond, VA
    Posts
    1,481
    ya i know. just trying to get other peoples opinions on what they think. i never touched that sides bearing before, but the driver side i did change the knuckle before with a new bearing, but i don't think i overtorqued the bolt. i did it till it was tight then a 1/4 turn back. hopefully weather lets up for me to check tomorrow.
  15. #15
    Riddle me that! slavrenz's Avatar
    2001 Mazda Protege LX 2.0
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    You may not have torqued the bolt enough. That bolt is supposed to be at least 200 ft-lb. When I did mine a few weeks ago, I ended up getting a 3 foot breaker bar, and making my 70 lb little brother stand on it. Voila! 70x3=210 ft-lb
Similar Threads
  1. Wheel bearing?
    By velothree in forum Protege5 Lounge
    Last Post: 11-01-2008, 04:07 PM
  2. Wheel bearing?
    By 323CiP5 in forum Protege5 Lounge
    Last Post: 05-29-2008, 07:56 PM
  3. Wheel bearing?
    By Jeff@Tri-Point in forum Photos, Videos & Builds
    Last Post: 05-25-2007, 08:56 AM
  4. Wheel Bearing
    By mygreenmazda in forum Protege Wheels, Tires, Brakes & Suspension
    Last Post: 06-05-2004, 09:15 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
