CorkSport.com is MAZDA PERFORMANCE!
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Tightening the e-brake
  1. #1
    Registered Member sm4rtf00d's Avatar
    2k2 Pro 5
    Join Date
    Aug 2003
    Location
    Springfield MA
    Posts
    230
    Has anyone done it? my e-brake doesnt hold @ 1200rpms... it sounds simple so i dont feel like paying someone to do it...
  2. #2
    FREAKY, BUT I LIKE IT!!!! mp3-79bronco's Avatar
    2001 protege mp3
    Join Date
    Dec 2007
    Location
    Howe, Texas
    Posts
    1,945
    pull the little plastic cover off around the handle and there is a 10mm nut on the side of the lever....tighten it
  3. #3
    2k2 Pro 5
    Join Date
    Aug 2003
    Location
    Springfield MA
    Posts
    230
    sweet tx... will do it in the A.M.
  4. #4
    Silver Bullet Away! SuperProtege5's Avatar
    2004 Mazda 3 2.3
    Join Date
    Mar 2006
    Location
    Pflugerville, TX
    Posts
    946
    this may sound stupid, but how do you pull the cover off?
    2004 Sunlight Silver Mazda 3s 2.3
    Modifications:
    Performance: Injen CAI, Mazdaspeed SS, Re-wired MAF Sensor, Hawk HPS Brake Pads
    Suspension: GT Spec Chassis Brace
    Cosmetic: LED Interior Light Conversion, Illumincs Ultra White High Beams, RPM Sharkfin Antenna
  5. #5
    2001 protege mp3
    Join Date
    Dec 2007
    Location
    Howe, Texas
    Posts
    1,945
    just pull towards the top by the console door in the slit
  6. #6
    Registered Member P-Funk!'s Avatar
    Lancer Ralliart Sportback
    Join Date
    Jul 2002
    Location
    Chesapeake Beach, MD
    Posts
    3,291
    OPen the console door.
    Put the brake ~only halfway up. IIRC.
    Pull the rubber/plastic surround up and forward. It is a 'lip' at the bottom.
    The bolt is on a long stud - use a deep well socket and long extension.
    Tighten - but be sure to check that the brakes don't drag. Stop on a slight incline and see if the car will start to roll when you release the brakes. After driving awhile - feel the calipers - they should warm but not hot (compared to the front).
    If you have to tighten the parking brake a lot and it still doesn't hold - you need to jack the rear end and check each caliper adjustment (the allen key you 'turn the pistons in with').
    I used to have a
    Black Mica Protege5
    Mods:
    MP3 ECU
    Hawk Pads
    OBX Header
    AWR Mounts
    Tokico Blues
    Eibach Pro Kit
    Underdrive Pulley
    Kartboy Bushings
    ThermoBlok Spacers
    Kumho ECSTA AST tires
    Fabricated Ground Wire Kit
    VTCS-Less Intake (Ported)
    Fabricated SRI w/ K&N Filter
    Fog lights on with parking lights
    Audio:
    Kenwood Head Unit
    Kenwood Mono Amp
    Custom 10" Enclosures
    Boston Accoustic 1" Tweets
    Rockford/Fosgate Punch 50
  7. #7
    Josh
    Join Date
    Oct 2007
    Location
    Atlanta, GA
    Posts
    543
    OK let me bring this back. I have tighten the bolt next to the handle until it is just about to start dragging. (ie. the max it can go) But it is still far from enough for me.
    So the solution now is work on the caliper right? How do I do it? I don't mind to read some article if there is any.
    Thanks
  8. #8
    Registered Member
    Join Date
    Dec 2007
    Posts
    11
    I do believe there is a 12mm nut on the back of the caliper you have to take off, under that nut there is an allen screw you can tighten. that will turn the piston so there is less travel and tightning the parking brake.
    Hopefully this helps
  9. #9
    Registered Member
    Join Date
    Dec 2008
    Posts
    7
    This post was right on time... I just changed my calipers and rotors on my P5 and had no clue on how to adjust the e-brake. Thanks Guys!!!
  10. #10
    Registered Member Benji's Avatar
    Mazda, Protege5
    Join Date
    Jun 2008
    Location
    Boston
    Posts
    35
    Careful, adjusting the calipers and the E-brake are totally different. If you tighten the calipers they will always be tighter and therefor your brakes might drag. To tighten the E-brake you need to tighten the line that runs from the E-brake to the brakes I.E. tighten the nut in the console.
    http://www.mazdas247.com/forum/showt...hlight=E-brake
    This is a how to on replacing your rear brake pads and rotors. While it doesn't explain how to tighten your e-brake it does show you how to adjust your calipers.
  11. #11
    Join Date
    Jul 2002
    Location
    Posts
    3,291
    Lastly- IT IS A PARKING BRAKE! If you are trying to use it for something other than holding the car on a hill and in-gear it isn't designed to do it.
    If you crank it all down too much (drifting. yo.) I fear you will either wear/overheat your brakes (dragging) or you will break the cable or both...
  12. #12
    ~ The name's Kevin ~ KZL_99ES's Avatar
    Donated: $50
    2005 VW Golf TDI
    Join Date
    Sep 2007
    Location
    Fort Collins, CO
    Posts
    1,480
    whoa now! i thought the e-brake was just fo gettin' sideways yo?
    1992 Mazda Miata & 2005 VW Golf TDI
    Please follow the For Sale Rules...
    http://www.mazdas247.com/forum/showt...=1#post1523129
  13. #13
    Josh
    Join Date
    Oct 2007
    Location
    Atlanta, GA
    Posts
    543
    Shiii...don't tell people that's the reason I need it tight.
    I do worry that mine can't hold the car on the hill though, but you can always use the gear i guess
  14. #14
    Josh
    Join Date
    Oct 2007
    Location
    Atlanta, GA
    Posts
    543
    So, if I already tight the 12mm bolt until it is about to drag and still not enough for me, should i put my attention onto the caliper or that is all i got?
  15. #15
    Join Date
    Jul 2002
    Location
    Posts
    3,291
    You need to ensure the entire system is working properly.
    1. Jack and check the caliper adjustments. Tighten the allen screws until the brakes drag. Back off a bit until the wheel can be turned easily.
    2. Adjust the 10mm bolt until after the handle is released it starts to cause the wheels to drag. Back off until they don't.
    This is as good as they can be.
Similar Threads
  1. Tightening E-Brake
    By Flagship in forum Protege5 Lounge
    Last Post: 01-28-2008, 10:33 AM
  2. Tightening of Hood Latch Wire
    By kevcouto in forum Protege5 Lounge
    Last Post: 05-09-2007, 06:25 PM
  3. drive belt tightening
    By rit14623 in forum Protege5 Lounge
    Last Post: 10-20-2005, 04:14 PM
  4. header bolt tightening order?
    By fLyPiNoY7 in forum Protege Performance
    Last Post: 10-03-2005, 09:36 PM
  5. Wagner shorty (or any header?) tightening issues?
    By Dimitrios in forum Mazda Tech & How-To
    Last Post: 01-21-2005, 05:59 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
