bullaculla
FINALLY DONE!!! ...for now. (UPDATED)
Been working on this for awhile, but didn't want to post until it was all complete. This is a total budget build. I built the box, and installed everything myself in my garage. I spent just around $1200. I am NOT trying to win any competitions here, I just wanted some better sound for a little bit of money and got quite carried away. But now I have a solid multimedia system in my Mazda5
Orion 2 channel amp wired in mono and 10" Kicker CVT in my custom box. Box is sealed and has about .7 cubic feet with some polyfil. Less than kicker recommends, but I did not want to make the box too big.
Fully functioning 3rd row seats.
The speaker "guards" are just some black chrome drawer pulls from my local hardware shop. I originally planned to mount one on each side to make installation/removal easier, but they ended up like this in case I need to put something on the box.
Full access to spare tire and tools. Some visible sound deading material.
It takes some work to get the jack past the little .5 farad cap, but it does come out. Cap is mounted to a plate I made, which is mounted to the side wall with some unused factory bolt holes.
I made the amp enclosure a little bigger than necessary in case I wanted to go bigger later. I made it so the 600.2 will fit in there.
There is a hole under the amp with a little computer fan under it to circulate the air. Plus its on blocks. Fan turns on with the amp.
Grey stuff is just some textured fleck stone from a spray can.
I didn't want to mount the amp upside down, but this way keeps the ground wires short.
The most time consuming part is making this curve. Explanation at the end.
Shot from inside. The flap on the back seat that used to attach to the storage cover, is attached to the box so that nothing will fall down between the seats and the box.
Action shot. The cone will travel a lot more, but this was at home and a little late in the day to be vibe-ing out the neighbors... Folded down seats are flush with the box.
HU pics.
I love this stereo. It can even play Mpeg from the USB flash drive. It also has full IPod control, but I dont have an IPod ...yet.
JVC LCD.
The LED lights replace the stock dome lights and work with just as the stock would with OFF-DOOR-ON function. There is a switch on the side of the unit.
Sorry, not many DVDs in my car yet. It was either this or Barbie Fairytopia, Magic of the Rainbow (blarf)
There is an arm to swing the LCD down lower and locks in place. LCD can also twist a little to each side.
And yes, it blocks the rear view mirror in this position.
Luckily I installed a Panasonic back-up camera. You cant even see it while standing up. It turns on when put into reverse. I plan on wiring up a switch to turn the camera on whenever I want. The rear camera will interrupt the LCD on the HU, but not the roof LCD.
You can see the lines around my camera where the factory camera would be if we were in Japan. The most frustrating part of this whole build was fishing the camera cable through the back door. The door is plastic, and the inner part is actually fused to the outer skin, making it nearly impossible to fish the thick wires through without removing the back window. Amazingly, after 3 days of trying, I got it through and then ran the wires through the factory rubber boot, and into the headliner.
DONT RUN OVER THE KIDS!!!
Mic for the Kenwood bluetooth unit.
Now for the installation pics
Thats where the bluetooth unit lives. You can even play/control mp3's from cell phone via bluetooth on the stereo. You don't even have to take the cell out of your pocket! (rockon)
I had to make a bracket/mount for the camera out of G10 garolite. The bolts have locktite and epoxy so it will never come apart or be stolen. From the outside anyway...
Sealed and mounted with silicone from the inside of the door. I used scrap sound deadening material as tape for my wires
That box is the controller for the Panasonic back up camera. You can also see the speaker baffles/cups I used, and some sound deadening material wherever I could reach. Speakers are running off the HU.
Partially covered trunk floor. I used Second Skin Damplifier to deaden my 5. I did the floor up to the drivers seats, most of the roof, 2 layers on the rear wheel wells, the front doors, license plates, back door interior cover, and wherever else I could shove my hand in.
You can see some factory sound deadening material on the floor. Sorry, I didn't take any after installation shots. I was too sweaty
Roof was the easiest to mat, and made the biggest difference. LOOK AT ALL THOSE AIRBAGS!!! Kinda scary...
LCD bracket. This thing is heavy duty. I wanted it a little more forward, but it would have interfered with the sunroof. I still have full sunroof function in this position.
Clamping curved face of speaker box. I let that curved piece sit in a bending jig for about 3 weeks before assembly, so that it would hold some of that bend on its own.
It still took a lot of force to get it into position. There are temporary braces in the box to help it take shape while I screw the box together. I left the clamps on for a few days after assembly to make sure the glue was completely dried and sealed. If you try this, leave the piece longer than necessary to give you more leverage. Then cut off the excess after its built.
If you search for my name, I did a similar speaker box install on my Mazda3 a long time ago. But that was really simple compared to this.
On this build, I really didn't want to cut or drill anything. Most of it can return back to stock except the roof LCD. The only holes I drilled/cut were: the hole I made for the backup camera, the hole I drilled in the plastic clutch hole plug in the firewall for the amp cable, the tiny holes holding the amp fuse, and the huge hole I made for the roof LCD in the headliner (which is a PITA to get out)
Thats it! Hope you like my build. If you have any questions, feel free to ask, but I am NOT an expert on car audio! So dont ask too technical questions. This is actually my very first time replacing a head unit with an aftermarket stereo, and my first time working with a cap. I just have some basic electronic knowledge and have a full woodworking shop, so I know how to build/design a wooden box to fit a car. I don't know if its the most efficient design for acoustics, but it sounds great to me
Equipment:
Head unit
-Kenwood DDX512 (from Crutchfield so I got the free dash kit and harness)
-Kenwood KCA-BT200 bluetooth interface (Ebay)
-Kenwood KNA-RCDV330 remote control (Ebay)
Speakers
-Kenwood KFC-C6882ie (also from Crutchfield so I got the free adaptors)
Amplifier
-Orion Cobalt CO300.2 (Ebay)
Subwoofer
-Kicker CVT10 4-Ohm (Ebay)
Capacitator
-Rockford Fosgate .5 farad cap (Ebay)
Amp wiring kit
-Rockford Fosgate FRK8I 8 gauge amp wiring kit (Ebay)
Roof LCD
-JVC KV-MR9010 9" Overhead LCD (Ebay)
Back up camera
-Panasonic CY-RC50KU (Ebay)
6x8 speaker baffles
-Boom Mat slim baffles (Ebay)
Sound dampener
-Second Skin Audio Damplifier (ordered direct)
Updates on page 3 and 4.
HU pics.
JVC LCD.
Equipment:
Head unit
Speakers
Amplifier
Subwoofer
Capacitator
Amp wiring kit
Roof LCD
Back up camera
6x8 speaker baffles
Sound dampener
