Your Best Source for Genuine Mazda Parts!
Results 1 to 11 of 11
Thread: Cigarette lighter dead - not the fuse
  1. #1
    Registered Member
    Join Date
    Nov 2008
    Posts
    2
    The cigarette lighter/outlet in my MS6 doesn't have any power. I checked & swamped the fuse but that didn't fix the problem. Has anyone else run into/resolved this issue? I'm hoping to avoid a trip to the dealership. TIA for your help.
  2. #2
    Passes on the right wheresthericego's Avatar
    BG 323 boosted, NA8 miata
    Join Date
    Jun 2006
    Location
    Raleigh, NC
    Posts
    114
    I hate ppl who say TIA. Go outside and figure it out
  3. #3
    LVT Aftermarket Parts LV Tunerz's Avatar
    07 MS6 GT
    Join Date
    Feb 2008
    Location
    IN UR FACE
    Posts
    276
    ditto
  4. #4
    Registered Member
    Join Date
    Nov 2008
    Posts
    2
    Hate? I'm sorry that something so little would elicit that kind of response.
  5. #5
    Join Date
    Jun 2006
    Location
    Raleigh, NC
    Posts
    114
    Its annoying to people who try to help others. It says that you have not tried to figure it out other than check the fuse. Shit do you even own a volt meter?
  6. #6
    Registered Member
    Join Date
    Jan 2008
    Posts
    25
    mine doesn't work either, but don't really care to fix it
  7. #7
    Join Date
    Jun 2006
    Location
    Raleigh, NC
    Posts
    114
    Lol
  8. #8
    So Owls can Drive? JinxKwB's Avatar
    2005 Mazda 6 i
    Join Date
    Apr 2008
    Location
    Michigan
    Posts
    168
    Many people say, it's not a fuse. Then they find they didnt check the engine bay Fuses. Also, some fuses dont look blown when in fact they are SLIGHTLY. Now, IF you checked BOTH places, checked ALL your fuses. and replaced the ones labeled as the cig lighter, and still no power, then you managed to fry the wiring. So you have to run a new circuit. It's not that hard.
    -JINX-
    Crash Test Dummy Tech
  9. #9
    Registered Member
    Join Date
    Mar 2009
    Posts
    1
    Smile hi
    charge your battery , i heard low voltage can turn off your cigarette lighter
  10. #10
    Registered Member tunersteve's Avatar
    Donated: $10
    2011 Mustang GT
    Join Date
    Dec 2004
    Location
    Downriver, Michigan
    Posts
    13,438
    Are you checking when the vehicle isn't in the ACC/ON position? The lighter doesn't work unless the key is present, same with the power plug inside the console.
    Take a voltmeter outside and check for 12V in the lighter. If not, pull the center tunnel apart and check the leads to the lighter and see if they supply 12VDC. If that's still a no, make sure the fuse terminals supply it. Trace your wiring, then come back and let us know what you find.
    If you don't own a volt meter, a simple one from Sears will work fine for under $40, just make sure it measures to mV, and it will be useful for many applications. My personal choice if you're going all out would be a Fluke 87.
    Steve
    2011 Mustang GT Premium
    430 rwhp / 409 rwtq
    Have a question - PM me
  11. #11
    Registered Member
    2002 mazda 626
    Join Date
    Jan 2013
    Location
    haddon twp
    Posts
    1
    I just fixed my mazda 626. The fuse is under the dash, it's labeled p.somthing i can't remember so yes try the fuse.. if you have any questions reply to my post..
Similar Threads
  1. Fuse for Cigarette Lighter
    By Alan in forum Mazda Tech & How-To
    Last Post: 03-03-2012, 12:29 AM
  2. Always on Cigarette Lighter
    By jrv331 in forum Mazda6 Audio
    Last Post: 10-17-2007, 04:41 AM
  3. cigarette lighter
    By Vampyre in forum Completed Transactions
    Last Post: 04-20-2005, 09:56 PM
  4. Cigarette Lighter
    By t3ase in forum MSP Archives
    Last Post: 07-10-2003, 11:51 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
