Your source for Mazda shift boots from Redline Goods!
Results 1 to 6 of 6
Thread: P0090 code FPR circuit
  1. #1
    Registered User dstmsp03's Avatar
    2003.5 MSP
    Join Date
    Feb 2008
    Location
    Belpre Ohio
    Posts
    2,702
    Items for Sale
    ive searched and really nothing around here to find out what to do to fix this.. car falls flat on its face lean at time and then jumps to 11.2-11.5 on the wideband at WOT at 12-14 psi.. anyone have any ideas on how to fix this?
    2003.5 Titanium MSP #307: Under Construction!
    2004 VR RX-8 GT: Stage 3 ported rotary from rx7 store, Greddy turbocharger, Mazsport intake, MM Cobb accessport, Optima Yellow top battery, Greddy Strut bar, Greddy air difuser, racing beat exhaust, RP supercat midpipe, ACT Prolite Flywheel, Exedy Stage 1 clutch, Reinforced clutch pedal, Greddy oil catch can, AEM Truboost, AEM meth kit, Innovate wideband. Lotek center Gaugepod, Blitz Fat turbo timer, VR Painted Eyelids, Tein S-tech springs, LED Bulbs, Tein hood dampers, Carbon Fiber door pillar covers
    2006 Hummer H3: Luxury with chrome package, 8 inch flip down dvd, 20% tint!
  2. #2
    2003.5 MSP
    Join Date
    Feb 2008
    Location
    Belpre Ohio
    Posts
    2,702
    Items for Sale
    no one?
  3. #3
    Registered User
    Mazdaspeed Protege '03
    Join Date
    Nov 2008
    Location
    Ohio
    Posts
    33
    Items for Sale
    I'm from Toledo, same thing happened to my car it would hit boost cut only when cold(30F-35F), like it has been lately in Ohio, does it feel like you got thrown back in your seat, ya that's fuel cut, Split Second has fuel cut defenders (aka. MAF voltage clamps), i believe they have to custom make them because mazda uses unconventional methods of signal ( amps and voltage ) have to goto the ECU... or just get a JoeP Fuel Cut Defenser and calibrate it. (Joe P uses boost to flip a switch to activate his circuit to fool the ecu into not fuel cutting, Split Seconds is a processor)
    I'm at 11 psi btw.
  4. #4
    2003.5 MSP
    Join Date
    Feb 2008
    Location
    Belpre Ohio
    Posts
    2,702
    Items for Sale
    it feels dead in its tracks.. nothing then all of a sudden it just throws me.. i dont run a split second.. i am running a unichip.. and it doenst do it when its cold.. when its cold out.. i am boosting like a champ! and it feels freaken perfect with 11.2-11.5 on the WB boosting to 14 ish.. i am going to try changing my FPR and checking that damn circuit setup for the car also.. hopefully i can find this issue
  5. #5
    Registered User
    Join Date
    Nov 2008
    Location
    Ohio
    Posts
    33
    Items for Sale
    What plugs are you running? A lean reading could mean a misfire also.... does the unichip box have a built in fuel cut defender, I would assume it would?
    Also you could measure the resistance from the control circuit of the FPR to ground and see if it reads infinite. If it does replace the FPR regulator like you suggested.
    You don't have any misfire codes do you?
  6. #6
    2003.5 MSP
    Join Date
    Feb 2008
    Location
    Belpre Ohio
    Posts
    2,702
    Items for Sale
    no misfire codes.. I'm replacing the fpr any ways.. U know where the fpr circuit is located?
Similar Threads
  1. Random Misfire Code and Cat Code
    By army88brat in forum 2.0 Tuning
    Last Post: 11-07-2008, 03:08 AM
  2. Add-A-Circuit 10 amp max?
    By Retrobmx63 in forum Mazda3 & MAZDASPEED3 Car Audio & Electronics
    Last Post: 02-06-2008, 08:02 AM
  3. Add A Circuit
    By amsgator in forum Car Audio & Electronics
    Last Post: 06-03-2007, 02:10 PM
  4. Check Engine Light - Code P0678 - Shift Solenoid Circuit - Help?
    By KamalaMP5 in forum Mazda Protege 5 (Protege5.com)
    Last Post: 02-28-2006, 11:00 PM
  5. thrown code? heater circuit sensor
    By sweetlou69 in forum MSP Engine, Performance & Forced Induction
    Last Post: 09-07-2005, 12:33 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
