Upgrade your Mazda with High Quality Parts at Great Prices from James Barone Racing!
Results 1 to 9 of 9
Thread: P0421 Code
  1. #1
    Registered Member
    Join Date
    Oct 2008
    Posts
    25
    P0421 Code
    HELP. Getting this code on my 2002 protege 5,(P0421). 100,000 miles. Replaces plugs, replaces wires, both sets, whole egr valve (BRAND NEW), all vacuum hoses, O2 Sensors front and back (NEW). Erased check engine light went to smog and said FAILED because couldn't complete OBD self tests. Have to drive 80 - 100 miles and bring back. What gives. Any suggestions. Please don't say CAT. YIKES.
  2. #2
    Bassist butchblack's Avatar
    Mazda Protege5
    Join Date
    Feb 2008
    Location
    Waltham Ma
    Posts
    18
    Quote Originally Posted by themodefanatic View Post
    Sorry
    The code is either the cat or the pre cat. If you're just at 100K you might want to speak to the dealer they may fully or partially cover it under emissions warranty if your engine is stock.
    Mine does the same thing @ 115k so I'm expecting a 500-1000 bill next time I go for inspection. I might wait till after I fail as I can get an exemption in Mass if I spend enough on trying to fix it, in case there is other problems, but I like the car so I may just get it done right.
    Does anyone know if this is a common problem on 2002 Protege5's?
    Butch
    Butch
  3. #3
    Registered Member
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    145
    yea, you need a cat
  4. #4
    Registered Member
    Join Date
    Oct 2008
    Posts
    25
    which one there are two??
  5. #5
    Registered Member
    Join Date
    Sep 2008
    Location
    NJ
    Posts
    145
    the one right off the manifold.
  6. #6
    Backfires destroy MAF's!
    Join Date
    Jul 2008
    Location
    At your mom's
    Posts
    421
    ^ or replace with a header if your state is not crazy-strict on emissions...
    or
    Try doing the CEL eliminator (search) for your 2nd o2 sensor. I did, and it got rid of my CEL for now. I know my 1st cat is plugged, I'll replace it with a header when I get paid for my overtime...
  7. #7
    Registered Member
    Join Date
    Aug 2009
    Posts
    3
    2002 Protege5 @102,000mi-- Same issue: P0421 CEL and a puff of smoke when i start it after a day of sitting. Trying to put off replacing the front cat, but worried about damage being done to the back cat as a result. Seems to be a trend with P5's...
  8. #8
    Registered Member
    Join Date
    Aug 2009
    Posts
    3
  9. #9
    Riddle me that! slavrenz's Avatar
    2001 Mazda Protege LX 2.0
    Join Date
    Nov 2008
    Location
    Ames, IA
    Posts
    2,298
    Quote Originally Posted by riri2469 View Post
    This does happen a lot with the P5's unfortunately. And the code won't trip if the rear cat isn't working, since only the one near the exhaust manifold is monitored by the O2 sensors.
    RockAuto.com FTW - Walker exhaust sells a new pre-cat for about $260.
Similar Threads
  1. CPE CAT failure - CEL code P0421
    By steefnap in forum Mazda6 Engine & Transmission
    Last Post: 10-22-2008, 12:43 AM
  2. p0421 code among others
    By brett02 in forum Protege5 Lounge
    Last Post: 01-04-2008, 11:14 PM
  3. Code P0421
    By LX_StreetGlow in forum Protege Performance
    Last Post: 10-19-2007, 01:25 AM
  4. Cel Code P0421
    By BlkMica_03 in forum Protege5 Lounge
    Last Post: 04-19-2007, 05:48 PM
  5. Thrown Code P0421
    By wiley858 in forum Protege5 Lounge
    Last Post: 04-03-2007, 05:27 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
