Show your support and Donate!
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: Best way to soften the suspension?
  1. #1
    Registered Member
    Join Date
    Sep 2007
    Posts
    115
    I am over the harsh ride of this car as I am not barreling through corners enough to take advantage of it. I don't mind a stiff suspension, but of all the sport compact cars I have owned this car takes it to an extreme. What are some ways to give this car a more comfortable ride? I was thinking dropping down to 17" wheels, but I am not sure that would make much of a difference.
  2. #2
    Registered Member Boosted333's Avatar
    '08 MS3
    Join Date
    Dec 2007
    Location
    Wallingford, CT
    Posts
    146
    I have 235-45-17's and it did soften the ride up a little bit. Plus they are 10 lbs lighter per tire/wheel, so straight line performance is better, as well as mpg.
    Dan L.
    '08 Mazdaspeed3
    Cobb SRI/AP/DP, TurboXS FMIC
    Custom tune from EFI Logics
  3. #3
    Registered Member o.g.sk8er's Avatar
    Join Date
    Jul 2002
    Location
    los angeles, ca
    Posts
    1,505
    I dont have an MS3, but my P-5 is super stiff.
    When I want a comfy ride, I just disconnect the rear sway bar.
    Stanced Member No. 5
  4. #4
    Registered Member CnoTataymo's Avatar
    08' MS3
    Join Date
    May 2006
    Location
    San Jose, CA
    Posts
    1,387
    Wow, you really think the MS3 has stiff suspension? I think it has soft suspension. What kind of sport compact cars have you had?
  5. #5
    Registered Member StealthWyvern's Avatar
    03.5 YLW MSP
    Join Date
    Mar 2006
    Location
    Jaxs
    Posts
    10,023
    a tire with a larger and or softer sidewall will yeild a much softer ride quality
    Quote Originally Posted by o.g.sk8er View Post
    sorry to thread jack but I agree sk8er my new MSP has a much softer ride with aftermarket springs and shocks w/ a drop compared to the stock suspension of the P5 with high mileage.
  6. #6
    I am not Rotus8 Rotus's Avatar
    07 MS3
    Join Date
    Jan 2003
    Location
    Houston
    Posts
    1,193
    As stated above, The easiest way to soften the ride is to soften the sidewall of the tire. You will lose steering sharpness, though. The most sidewall you can gain is by using a 16" wheel that will fit aound the brakes. I think some have used an 16" FD rim with success.
    Cosmic Blue 07 MS3, V1 hardwire, 20% tint, TRZ dogbone, MS CAI, TWM SS, Forge BPV, satin silver pc'd RX-8s (235/40), Corksport testpipe, Ventpod with Prosport electronic boost gauge, Yakima rack, 5k K HID lows and 3k K HID fogs, Medievil trans MM, Hawk PC fronts pads, cp-e TIP, stealthbox, Magnaflow catback, SM catch can, Corksport bypass hose, Hypertech tuner, AWR passenger side MM, Corksport lowering springs/dampers, Caska headunit, Sure SS knob. Dents and scratches like whoa.
    Yellow Speed coilover install tips
  7. #7
    Registered Member User Name's Avatar
    Join Date
    Jul 2007
    Posts
    145
    What about swapping the suspension from a regular 3. I'm sure you could find someone that would even pay you a few bucks for your MS3 susp and give you their stock parts.
    Balls
  8. #8
    Bits of real panther Kain's Avatar
    Join Date
    Jun 2003
    Location
    Alexandria, VA
    Posts
    4,116
    Quote Originally Posted by CnoTataymo View Post
    Agreed. On my last car, I had K-sports with 9k/7k f/r spring rates... now that's stiff. I could feel my dental fillings rattle out just going over smooth roads. Any bumps, fuggedaboutit. The stock MS3 rides like a Cadillac in comparison.
    2008.5 Mazdaspeed3 GT, True Red
  9. #9
    Registered Member
    Donated: $20
    2007 MS3
    Join Date
    Aug 2007
    Location
    Red Lion
    Posts
    485
    Quote Originally Posted by Boosted333 View Post
    I have that size tire. The ride is better without any loss of handling.
    2007 MazdaSpeed 3
  10. #10
    Registered Member wisniaPl's Avatar
    Join Date
    Feb 2008
    Location
    Long Island
    Posts
    1,612
    hehe I just hope that it came with stiffer suspension its soft for me but I dont want to lower my car....
  11. #11
    Registered Member
    Join Date
    Sep 2007
    Posts
    115
    Thanks for the replies. I have had a 98 GTI, 02 WRX, and an 05 RSX Type S before this car. It's possible I am just getting old, or I notice it more because my girlfriend complains about it every time she's in the car.
  12. #12
    07 MS3
    Join Date
    Jan 2003
    Location
    Houston
    Posts
    1,193
    Quote Originally Posted by Kain View Post
    LOL @ UR avatar. It goes to eleven, doesn't it?
  13. #13
    Registered Member
    Join Date
    Aug 2007
    Location
    SE Michigan
    Posts
    677
    Quote Originally Posted by PeterC View Post
    ... my girlfriend complains about it every time she's in the car.
    I hate that!
    I notice the MS3 being particularly sensitive to frost-heaves or any type of bump ~1 inch tall that you cross perpendicular to. I've actually memorized where most of these are on my commute so I can change lanes ahead of time to avoid them! At one point I was trying 40psi in my tires and that made it seem like the dashboard would fall off... I run 37 now and it's better, so that leads me to believe that a few less pounds of air or a softer sidewall would help a lot. Try running the minimum recommended pressures before you spring for new tires.
    Brian
    08 BlackMica MS3 GT StreetTire D-Stock
  14. #14
    Reformed mustang owner.
    08 RED MS3
    Join Date
    Jun 2008
    Location
    Minnesota
    Posts
    39
    Trade it in on a regular mazda 3.
    Twin Cities Mustangs
    Bart: I smell a museum.
    Homer: Yeah, good things don't end with 'eum,' they end with 'mania' or 'teria.'
  15. #15
    08' MS3
    Join Date
    May 2006
    Location
    San Jose, CA
    Posts
    1,387
    Quote Originally Posted by wisniaPl View Post
    Yeah, I would like it to be more firmer. I've got almost 13k miles on it and after the first 2k miles, I've noticed all the little stuff about the handling of the car. But it sure is a nice DD.
Similar Threads
  1. mazda3 suspension / mazdaspeed3 suspension
    By mrlilguy157 in forum MS3 Wheels, Tires, Brakes & Suspension
    Last Post: 05-05-2015, 03:53 PM
  2. Suspension Compression...how far? New wheels...
    By Pololo_MS3 in forum MS3 Wheels, Tires, Brakes & Suspension
    Last Post: 01-23-2008, 09:51 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
