J jville Member : 2007 MazdaSpeed 6 Jul 28, 2008 #2 bad guage cluster? does the odometer still work? Mazda can hook up the scan tool and do a guage sweep to see if the cluster is operative.
J jville Member : 2007 MazdaSpeed 6 Jul 30, 2008 #4 yea but the tach and the speedometer are 2 seperate circuits, could just be a short in the speedo part,
K Killer Member : 2011 3 5 door Aug 1, 2008 #6 lubricity said: Tack works Click to expand... *Tach, as in Tachometer.
J jville Member : 2007 MazdaSpeed 6 Aug 1, 2008 #7 then it sound like a bad cluster. take it somewhere and have them sweep it with the scantool and go from there.
W wannabe meh : 16 CX-5, Old: 06 Mazdaspeed6, 08 CX-7, 01 Protege ES/Mp3wannabe Sep 4, 2008 #9 make sure you check all the fuses, i'm sure that the tach and the speedo are probably on the same one, but someone above mentioned different circuits.
V VRMS6 Member : 2011 Kona Blue Ford Edge Sport Sep 5, 2008 #10 ebay had one for less than $100 last I checked...
