how to remove front bumper
MP5_85
Mazda / MP5
Hey does any1 know a link of how 2 remove the front bumper of the '03 Protege5 im tryin 2 fog my lights
Unscrew the bolts on the inside of the fender well(phillips), unscrew the bolts on the onderside of the front bumper that holds the undercarriage cover in place(10mm with phillips internal), pull fender covering back and unscrew to screws that hold the corner of the bumpers to the fender(Phillips, and the screws are next to the headlights. Lift up and out.
Should be three screws per fender well, eight bolts on the underside, and four screws holding the bumper tot he fender.
^Huh? Do you mean remove the headlight assemblies and take apart and paint? Or do you mean replace a fog light assy. or change a bulb?
It makes a big difference in the amount of work you need to do.
