Mazdaspeed 3 Autocross Tire Pressures
What tires are you running? And what kind of suspension set-up do you have?
I'm running stock suspension and tires. I last ran around 41 in the front and 32 in the back. Worked well for me, don't seem to be rolling on the sidewall on front or back. Of course it comes down to the driver and their preference as well. May be a good place to start. You can also put a chalk mark between the sidewall and tread to see how far you're rolling over on the sidewall after a run and adjust your pressure as you see fit.
