I have the 2000 1.6 dohl motor, i changed the timing belt and made sure to make everything from the crankshaft and the camshafts, put it all back together several times and still get no start. I have tried to take it apart and put it back together about 4 or 5 times now. I cannot figure out why this will not start. I checked the cyllinders and the 1st and 4th are all the way to the top, the cams and crankshaft are aligned but still no start.
Does anybody have any suggestions? and is this a non interference or interference motor? Thank you.
